Saginaw conversion with Hydroboost pump Question
Old Apr 29, 2023 | 05:10 PM
Blue460's Avatar
Blue460
I am converting my 1994 460 XLT F250 to a saginaw power steering pump using the van power steering/ AC bracket, and upgrading to hydroboost at the same time. Can any hydroboost saginaw style pump work? I am leaning towards using the PSC SP1404 pump, I also have the original van pulley if that's important.
Old Apr 29, 2023 | 10:10 PM
obsxl's Avatar
obsxl
following because I’d like to do the same thing to mine, but also don’t know what high pressure hose to use to go from the pump to hydroboost
Old Apr 30, 2023 | 08:40 AM
Scndsin's Avatar
Scndsin
Can't speak to the sag running hydro-boost,(likely it will) but you will need to use the van pulley.
Shaft diameter is different from the std Ford corporate pump that your truck came with.
Doubt you will find a stock hose, most likely you'll need to get one made.
Old Apr 30, 2023 | 11:00 AM
PRIMERED79 SHORT BED's Avatar
I've done the sag conversion on my f150, but since I've done a SAS and have 35" tires the brakes are pretty weak so been debating doing the hydroboost as well, just subscribing to learn more on it.
Old Apr 30, 2023 | 01:50 PM
obsxl's Avatar
obsxl
if using a non-van saginaw pump, will any 6 rib saginaw pulley work or do you still have to use a van pulley?
Old Apr 30, 2023 | 04:49 PM
Scndsin's Avatar
Scndsin
Finding a Ford spec sag pump that bolted in the original bracket used to be relatively easy.
Then they stopped rebuilding them. So I don't' know where you'd get a sag that takes a Ford pulley.
Take your calipers to the JY:
XSoph
Aug 21, 2020 06:26 PM
1985 Bronco
Dec 7, 2018 12:50 PM
Muldo
Sep 29, 2008 03:32 PM
Jeff-150
18
Feb 4, 2008 07:52 PM
Hit Man X
Oct 13, 2003 08:31 PM
