Rear brake wheel cylinder 75 f250 4x4
Old Apr 25, 2023 | 06:18 AM
jdel80's Avatar
jdel80
Need a little help please, I have a 75 High Boy drum's on all 4 corners, my left rear wheel cylinder is leaking, I have not opened it yet, but I did go to Rock Auto to snag one, but WOW there are a ton of diff. it seems, Does anyone know the one I need hopefully,
Any Help is appreciated
JD
Old Apr 25, 2023 | 08:03 AM
nutter3's Avatar
nutter3
Hello JD,
I just redid the rear brakes on my 75 highboy. I was going to rebuild my wheel cylinders, but they were too pitted. I bought these at Autozone and they were an exact match.1 @ 1/12.49 000189407 33600 33600 Duralast Wheel Cylinder EA $12.49 P 1 1 @ 1/12.49 000189415 33601 33601 Duralast Wheel Cylinder EA $12.49 P 1
Old Apr 25, 2023 | 08:09 AM
jdel80's Avatar
jdel80
Perfect thank you for helping ....
Old Apr 25, 2023 | 08:19 AM
jdel80's Avatar
jdel80
Kewl just ordered , might as well do both while on jack stands
JD
Old Apr 25, 2023 | 11:11 AM
Olblack's Avatar
Olblack
Might want to check the bearings n seals.
Old Apr 25, 2023 | 01:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D3TZ-2261-B Right & D3TZ-2262-B Left .. Rear Wheel Cylinders - 15/16" diameter / Obsolete
1973/75 F250 4WD
Old Apr 25, 2023 | 11:19 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do not forget to get the 1/2 drive 2- 9/16ths thin wall socket to get the double axle nuts loose. Unbend the lock tabs 1st. After you pull both the axles.
h.ubk
Aug 5, 2022 01:33 PM
richardchad
Large Truck
Jul 19, 2011 02:11 PM
Brad Leroy
Apr 27, 2010 12:28 PM
Coneynew
Jul 1, 2008 09:47 PM
