Radio whine when cold.
Old Apr 18, 2023 | 09:57 AM
OBS4ever's Avatar
OBS4ever
I have a 1993 with the original head unit. In the morning when my truck is cold the radio makes a awful high pitched hum. It also happens when the engine is off. Once the engine is warm and the outside temperature is warm, the whine is gone. I believe it could be a loose ground or antenna. I just upgraded speakers and they sound much nicer than original, but they aren't the problem as the whine is still there. I have no clue where to start and would much appreciate info on this type of problem.
Old Apr 18, 2023 | 10:05 AM
sandymane's Avatar
sandymane
The radio ground is the strap from the hood to the firewall. Maybe cleaning it up will help.
Old Apr 18, 2023 | 12:17 PM
OBS4ever's Avatar
OBS4ever
My truck does not have a ground connection on the hood.
Old Apr 18, 2023 | 12:21 PM
sandymane's Avatar
sandymane
This is the 5th OBS I have owned and never seen one without it. Maybe that is your issue? Just looked at my 95 and there is one connection on the hood and one on the firewall. I would imagine the hood is the one.
Old Apr 18, 2023 | 01:29 PM
OBS4ever's Avatar
OBS4ever
That is more what my wiring setup is. My truck is a 93. Whenever I hit a big bump when driving, the tone of the hum changes.
Old Apr 18, 2023 | 01:31 PM
sandymane's Avatar
sandymane
OK Hope it will clean up good and work properly for you. Sandy
Old Apr 18, 2023 | 02:04 PM
OBS4ever's Avatar
OBS4ever
Here is my connections. What is the red wire connected to the hood.
Old Apr 18, 2023 | 03:02 PM
sandymane's Avatar
sandymane
It really doesn't matter what they go to. They are ground straps and they need to have a GOOD connection to ground. You can not have to much ground.
Old Apr 19, 2023 | 08:06 AM
Scndsin's Avatar
Scndsin
Your problem is most likely 99% inside the unit if clearly time based from cold to warm.
The braided ground straps to things that have no electrical component (hood, rocker panels, etc.) have been reported to be for Radio Frequency Interference.
To reject it as well as contain. Think Faraday cage.
I'd try swapping out capacitor that is mounted to the coil frame.
If still there you could pick up a radio JY spare, (not necessarily an exact match, base unit would be fine), plug it in & see.
One of the two I bet will get rid of your whine.
Old Apr 19, 2023 | 08:54 AM
OBS4ever's Avatar
OBS4ever
How do I post a video. I have taken one of the problem but cannot figure out how to post it into the thread.
Old Apr 19, 2023 | 05:33 PM
OBS4ever's Avatar
OBS4ever
How do you post a video. I have taken a clip of the noise.
Old Apr 20, 2023 | 12:45 PM
OBS4ever's Avatar
OBS4ever
After some research. I figured it out. What do you think is causing this sound.
Earnest1975
2009 - 2014 F150
Jan 19, 2020 04:57 AM
caere
2009 - 2014 F150
Nov 18, 2017 08:19 PM
Tdraym
Dec 15, 2013 09:52 AM
CMPX2
Nov 15, 2010 02:08 PM
secretagentman
Dec 13, 2006 09:46 AM
