'01 F550 farm truck rebuild
Old Feb 19, 2023 | 05:24 PM
Diesel nut's Avatar
Diesel nut
My original post got screwed up somehow. '01 F550 with over 10k hours on the original engine and 125k on the odometer. Odometer doesn't work so not sure how many miles are on it. Had an aerial bucket on it for most of its life and was removed before we bought it. Was used as a service truck until we replaced it with a newer truck. Decided to rebuild this one and put a flatbed on it and make it our tow beast. 400 hp is the goal and trans rebuild is needed anyway along with full engine rebuild. 180/30 injectors along with KC turbo 68/73 with .84 housing, reg return w/ bowl delete, CNC fab hpop, new water pump with integrated coolant filter which I think is pretty cool, Colt cams stage 2 cam, new lifters, Comp cams valve springs and .138 pushrods. Heads will be mildly ported. Hydra chip. And some other things to make it better.
Old Feb 19, 2023 | 05:51 PM
ESwift's Avatar
ESwift
CNCFAB
Sounds like a fun project!
with 180/30 I would recommend a stage 2 hpop.
Old Feb 19, 2023 | 06:04 PM
Diesel nut's Avatar
Diesel nut
Old Feb 19, 2023 | 06:05 PM
Diesel nut's Avatar
Diesel nut
Originally Posted by ESwift
Sounds like a fun project!with 180/30 I would recommend a stage 2 hpop.
Well I've already got the stage 1. They said it'll work with those injectors.
Old Feb 19, 2023 | 06:11 PM
ESwift's Avatar
ESwift
CNCFAB
Gotchya, just figured I would toss the idea in the ring. Maybe it was just the transmission stuff you hadn’t ordered yet? I wasn’t sure if you meant that or all the stuff.
It will work well, the stage 2 would just give a little extra flow if you decided to get rowdy with race tunes, but then again it is a f550 so rowdiness prolly wont be an often occurrence.
Old Feb 19, 2023 | 06:14 PM
Diesel nut's Avatar
Diesel nut
Gotchya, just figured I would toss the idea in the ringIt will work well, the stage 2 would just give a little extra flow if you decided to get rowdy with race tunes, but then again it is a f550 so rowdiness prolly wont be an often occurrence.
True, but it would be a good candidate for a sleeper. Lol a sleeper F550 just sounds funny. ​​​​​​​
Old Feb 19, 2023 | 06:15 PM
ESwift's Avatar
ESwift
CNCFAB
Blowing away other “fast trucks” in a F550 would be really fun!
Old Feb 19, 2023 | 06:17 PM
Diesel nut's Avatar
Diesel nut
Old Feb 19, 2023 | 06:21 PM
Diesel nut's Avatar
Diesel nut
Sure would! 4.88 gears will keep it limited on the highway lol but great for street territory. 😆 Might be hard explaining to the old man why it can't keep rear rubber on it. 4 of these tires ain't cheap!
Old Feb 19, 2023 | 06:46 PM
Diesel nut's Avatar
Diesel nut
How are you supposed to put pics on here? Is there a certain way to do it? Having a hard time figuring it out.
Old Feb 19, 2023 | 09:39 PM
Kwikkordead's Avatar
Kwikkordead
I have a 550 as well. Pulls like a train, but anything over 75 is a roaring monster with those 4:88 gears, LOL.
Old Feb 19, 2023 | 10:56 PM
idshred's Avatar
idshred
Are you putting oem forged rods in it? I would probably do the same thing since you have the engine apart. Not a necessity for the power levels you’re at but not a bad “while I’m in there” issue to address.
Old Feb 19, 2023 | 11:03 PM
Diesel nut's Avatar
Diesel nut
Yup I got a set on the way for $265
Old Feb 20, 2023 | 01:34 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
For the injectors you mention Full Force. If you mean Full Force Diesel and you did not buy them yet, don't! DO NOT! Very bad juju mon.
If I was in the market for injectors I'd pick Bitterroot Diesel. Will cost a bit more but they are tested to actually work properly.
Old Feb 20, 2023 | 08:35 AM
petrokiller's Avatar
petrokiller
Under quick reply look at the top row of letters and symbols.
Next to the smiley face is what looks like a stamp with mountain peaks.
Tap that and then pick from device the from files.
Easy once you get it a few under your belt
Looks like a big project
