Fuel filter after 5k miles
Old Dec 17, 2022 | 01:18 PM
speakerfritz's Avatar
speakerfritz
About 5k miles on this filter
inspite of using anti gel, algicide, water remover, this is one nasty filter after about 5k miles.
I ripped it open n cleaned ne of the squares to see if there was any fungus in the media and surprisingly the media actually looked fine.
so water ever that white (or was white) material is made of , seems to be doing it’s job as a pre filter media.
there is some slimy brown stuff on the water separator screen.
truck has 14k miles on it and this is filter set number two.
change the engine bay filter as well.
I have a DPK return filter but not sure if it needs changing since the fuel that hits it is filtered twice.
anyway…here’s your Saturday afternoon eye opener.
Old Dec 17, 2022 | 02:25 PM
Overkill2's Avatar
Overkill2
So are those three separate additives you use?
It sucks you can't measure the pressure at the HPFP like I can... or did you ever find out if you have that PID?
You change every 5k miles? Or was this just to see how a new additive was working?
Old Dec 17, 2022 | 03:02 PM
speakerfritz
for some reason, I can measure lift pump with forscan OBDLink (forgot which) but not with idash.
with idash I can measure rail requested vs actual and rail flow rate.
I went 10k on the stock filter and it looked as funky as this one so I was thinking to try 5k but didn’t expect it to be this funky.
im going to peak at it at 2.5k .
Old Dec 17, 2022 | 03:35 PM
Overkill2's Avatar
Overkill2
You should shoot an email to Banks and see what they say...
I definitely feel it's pertinent to monitor my fuel pressure at the HPFP as I take my filter CIs out with every third (7k miles) oil change as per the factory manual for my 16.
Are those additives all separate?
chadstickpoindexter's Avatar
chadstickpoindexter
Are you fueling up from the same place each time, or for the most part?
Old Dec 17, 2022 | 04:32 PM
speakerfritz
no
different places
mostly major state highway service stations .
and Costco until recently …they go out of the Fidel business
I stay away from local gas/deli type places.
Old Dec 17, 2022 | 04:33 PM
speakerfritz
the anti algae additive is separate.
the anti gel/water /lube is all in one opti lube.
Old Dec 17, 2022 | 05:30 PM
BC2019F250's Avatar
BC2019F250
That looks much worse than my filter that was changed at 30,000. I don't use any additives.
Old Dec 17, 2022 | 08:21 PM
tradosaurus's Avatar
tradosaurus
Why is your fuel filter square shape?
Old Dec 17, 2022 | 09:08 PM
Overkill2's Avatar
Overkill2
The 17s changed from our 11 to 16 gen trucks. It's a stand alone diesel fuel filter/water separator which their in tank primary pump pumps fuel to before it makes it's way up to the secondary fuel filter in the engine bay. No more DFCM like the 11 to 16s have...
Old Dec 18, 2022 | 08:41 AM
helifixer's Avatar
helifixer
here are mine after 30,000 miles.
ford was supposed to change them at my second oil change and didn't.
Old Dec 18, 2022 | 01:40 PM
chadstickpoindexter
That's kind of what my upper filter looked like... but it was also hard to say since I had to hack it open with a hack saw and there was still some fuel in it so there were plastic shavings all over too... I need to get one of those filter cutters like Overkill has!
Old Dec 18, 2022 | 04:38 PM
helifixer's Avatar
helifixer
The cutter won't open the plastic cases, at least mine wouldn't (identical to Dave's) I cut it open with a saw
Old Dec 19, 2022 | 07:16 AM
ToMang07's Avatar
ToMang07
Tagged and following here too...
Old Dec 19, 2022 | 07:59 AM
Painted Horse's Avatar
Painted Horse
I change mine every other oil change. Or about 20,000 miles. And mine has never looked that dirty. I'm not religious about additives. But do put Opti-Lube Summer in the warmer months and XPD in the cold months. Kinda hit and miss.
I do burn thru fuel. 3,000 miles a month or about 35,000 miles a year. Which causes me to wonder if the time in your truck might be considered. If 5,000 miles in your truck takes 12 months, does algae grow in your tank? I live in a very dry climate, Would living in high humidity and long cycles between consuming the fuel lead to growth? Just spewing ideas
