Oil in Injector cup
Old Dec 9, 2022 | 11:55 AM
smitty59's Avatar
smitty59
Oil in Injector cup
Well it's me again. After I finished the upgrades on the '02 7.3 I was impressed with the improvement in the torque while towing. Unfortunately while pulling a trailer approximately 40 miles the truck used over 2.5 gallons of Rotella T5, and yes I said 2.5 gallons. So my question is why is there oil sludge in #1 and #4 injector cups? I ordered 8 new Alliant 160/30% injectors,injector cups and glow plugs from BDP and when I pulled the injectors on the left bank(passenger side) #1 where it sits in the cup was covered in oil sludge same on #4 on the right bank. So can anyone tell me whats going on? No oil in the water,on the ground or in the fuel filter??????TOTALLY CONFUSED!!!!!!!
Old Dec 9, 2022 | 02:23 PM
FordTruckNoob's Avatar
FordTruckNoob
Not sure what you mean by “oil sludge in the cups”. Pictures would help immensely.
Pending that, do you have any noticeable oil leaks?
Old Dec 9, 2022 | 02:44 PM
smitty59's Avatar
smitty59
Yessir I am working on that now.
Old Dec 9, 2022 | 03:08 PM
smitty59's Avatar
smitty59
No oil leaks. All new Hpop lines,oil cooler rebuild and dipstick adapter. No drips on the ground, no oil int the degas bottle,no oil in the fuel filter and none coating the bottom of the truck.
Last edited by smitty59; Dec 9, 2022 at 03:15 PM. Reason: ccompared to other injector
Old Dec 9, 2022 | 03:40 PM
udsuth78's Avatar
udsuth78
How about the tailpipe? Nothing to do with your sludge, but what about the possibility of turbo dumping oil out the exhaust?
Old Dec 9, 2022 | 03:45 PM
helifixer's Avatar
helifixer
2.5 gallons in 40 miles through the turbo would leave the road completely fogged with oil vapor.
to loose that much oil and not have a white cloud following you it has to be one of the pink o ring's IMHO and from my experience
Old Dec 9, 2022 | 03:47 PM
helifixer's Avatar
helifixer
as for the oil sludge that would be from an orange o ring leaking
Old Dec 9, 2022 | 03:52 PM
knottyrope's Avatar
knottyrope
looks like wet exhaust blowby
what did the copper washer look like?
udsuth78's Avatar
udsuth78
I agree but if it's not showing any where else then it's at least worth a look. Are we sure the oil was full prior to the 40 mile trip?
Old Dec 9, 2022 | 04:56 PM
helifixer's Avatar
helifixer
good point on oil level,
all the blown turbo seal I have dealt with had oil dripping from the tail pipe
Old Dec 9, 2022 | 07:18 PM
smitty59's Avatar
smitty59
I rebuilt the turbo and upgraded the wheel with the KC Turbo Balanced Billet Turbo wheel when I did the first top end upgrades back in the spring. I am positive the crancase was full when I pulled out of the driveway. I have dual stacks but they are not soaked in oil. The copper washers looked ok.
Old Dec 9, 2022 | 10:33 PM
udsuth78's Avatar
udsuth78
I think we're missing something here, other than 2.5 gallons of oil. How did you come to realize the oil was low? To recap, 2.5 gal. lost in 40 miles and there are no leaks anywhere on the engine. The fuel filter is clean, and the exhaust is dry. Oh plus the coolant is spotless. If an injector o-rings blew it can dump that much oil in no time. Is it possible the oil is in the tank but hasn't made it to the filter housing yet? If it isn't there then it's still in the pan. That or aliens beamed it away for some probing. Lizard people maybe?
Old Dec 10, 2022 | 05:24 AM
FordTruckNoob
I was thinking about this too but then 2.5 gallons in that short a time would have shown on the fuel gauge, no? Furthermore, unless the OP has some kind fuel return from the heads that means the oil is going backwards through the fuel lines into the bowl.
Old Dec 10, 2022 | 08:19 AM
Kwikkordead's Avatar
Kwikkordead
I second this. Somehow the high pressure oil is getting sent to the fuel system.
Old Dec 10, 2022 | 08:22 AM
Kwikkordead
The answer is laying right in front of you. The injector on the bottom of the row, the pink o-ring is washed clean compared to the others.
