DPK (w/return filter) & after market Lift pump diccussion
understand that on a 2017 - 2019 both the stock and aftermarket lift pump will tyrn on and presureize...but the stock one will shut off after the system is pressurized...the after market one will keep runing...push retun fuel back up into the forward system.
Im going to email S&S and see what they think.
maybe this will work
I'll have to read my instruction again for the Air Dog but for the return line for the Air Dog, it goes to the fuel tank fill hose through a T fitting...
I'd contact S&S as well as AFE... I have a set of instructions printed out from AFE for the 11 to 16s for their AFE DS780 pump. I'll have to check it out again on their website to see if anything changed...
I made a hand drawing of what I wanted to do and what I needed to buy to install my Air Dog WITH the DFCM... I won't take a pic as it will confuse the eff out of people... I'll redraw it before I install and post up in my truck thread...
The old system that was preset at 10 PSI was sold to feed the DFCM that had the requirement of cutting of the fuel tank fill hose with a big tee fitting to return the fuel not used back to the tank. The newer 4G, they now have the 5G system which offers more pressure adjustment by hand with a easy to turn **** on the outside of the pump...anyways, has a smaller tee fitting for the return to plumb into the factory return line as this pump was meant to replace the DFCM but which I am NOT doing... I ordered extra fittings and will post tons of info when it's installed...
The later 4G 165 GPH unit, like the 5G 165 GPH unit for the 11 to 16 trucks is preset at 55 PSI to feed the HPFP. Air Dog sent the 10 PSI spring to me free of charge... I will add a fuel pressure gauge on the supply line between the Air Dog to the DFCM... that way I can get it dead nuts at 10 PSI.
Anyways, I believe the potential problem fritz is describing is for the Alumina Duty guys with an in-tank primary pump which would place the aftermarket pump "after," or closer to the HPFP unlike the 11 to 16 application of a aftermarket pump WHILE RETAINING the factory primary pump (DFCM).
The AFE DS 780 directions for the 11 to 16 application remained the same fritz as they also RETAIN the DFCM pump which their unit feeds.
On page 13, it starts to describe essentially what will be my fuel line connections with my Air Dog... just using the AFE for reference.
https://afepower.com/media/catalog/p...6.7l_td__1.pdf
Seems like if one was to mount that filter assembly that low and on the outside of the frame, that it'd be worthwhile to build some kind of shield around it for protection...
I moved mine to the cavity between the tank and the transfer case. I used some electrical u channel, painted it black, and cut the ends to a taper so I can get a socket on the bolts. Socket won’t fit in the uchannel. The bar runs from the transfer case cross member bolt hole indicated in the afe manual to the first bolt on the tank skid plate drivers side. The pump is tucked away nicely.
I had it in the stock position and a rock hit it and cracked my sight glass. Had to pull it off to replace the glass and some other things.
thinking of using a metal collar instead of the upper glass…where it sits now can’t see the glass anyway.
I also figured out I need one more 90 degree elbow to plumb in the "y" fitting that they include to plumb in the Air Dog return to the factory return... More info along with pics will come once it's installed but the S&S DPK kit has to go in first.
Here's a pic of the fitting that's included to use to replace THE DFCM, which I am NOT DOING, but it will definitely be used to plumb into the factory return line.
More info to come...
I need to get the tube that will let me run the return to the fill hose. I found a supplier for it.
I also need to double check to see if I have fittings to install to the new connect points.
I have the tools to make my own crimp hoses so I’ll be making hoses on the fly.
EDIT
Starting at about the 2 minute or so, they show the return fuel flow being dropped back into their demonstration fuel tank.
But truth be told, I am looking into fuel line check valves on Summit Racing and will post more info at one point.
Okay so now that I'm on board with this and finally see what I didn't before, here's some more info on check valves... because I gotta be honest...
I'm not too keen on throwing on a cheap @$$ Amazon check valve into the mix here... so here's what I came across.
*Russell makes a -8 AN fuel check valve here. they only make it in a -6 AN as another size...
Russell Check Valves
Russell check valves are designed to allow flow in one direction and prevent flow back. They feature a 304 stainless steel check piston that delivers optimum flow with minimal restriction and pressure loss. A positive O-ring seal is incorporated into the high-flow check piston. These valves are ideal for fuel systems due to their low opening pressure of 3 psi.
**Summit Racing -8 AN and -10 AN check valves here.
Summit Racing™ One-Way Check Valves
Summit Racing™ one-way check valves are designed to prevent the back flow of any fuel, coolant, or oils. Their flapper design provides minimal flow restriction, and the high-quality construction of these valves ensures long-lasting performance. Their PTFE flapper requires a low 2 psi to lift off of the seat and is resistant to alcohol, methanol, and bio-diesel fuels. These check valves are offered in a choice of sizes to suit your needs.
A couple of questions were asked about the Summit Racing check valves:
NICK
· 3 years ago
Summit Racing SUM-220194B - Summit Racing® One-Way Check Valves
Will this check valve work with standard american diesel fuel?DAVID
· 3 years ago
Yes it does. We install them on semi tractors frequently.
What is the backflow pressure rating as in how much pressure it will hold back before failure? Thanks!Thank you for your question. The Summit 220194B one-way check valve has an operating pressure range of 5-1500 PSI.
What is the outside diameter?Thank you for your question. The Summit 220194B One-Way Check Valves measure 4.00 in. long and have an outside diameter of 1.375 in.
***Redhorse Performance check valves...
Redhorse Performance 4152 Series One-Way Check Valves
Redhorse Performance offers 4152 Series one-way check valves to prevent fuel and oil flow back. Each aluminum check valve is fully fuel and oil compatible and armed with a PTFE stopper. They are available to fit -04 AN through -12 AN fittings with male threads, in your choice of red, blue, clear, and black anodized finishes.
****Fuel Lab check valves here. Again I'm looking at the -8 AN and the -10 AN. I'm thinking the -8 AN will suffice but I'm bringing the bigger -10 size into the conversation.
FUELAB high-flow, one-way check valves are designed to deliver maximum flow with minimal restriction and pressure drop. Featuring -6 AN, -8 AN, and -10 AN male inlets/outlets, 350 gph flow capacity, cross fuel compatibility, and billet aluminum construction, these advanced engineered FUELAB valves allow for easy installation and prevent flow back after pump shut down. The check valves are rebuildable, have fluorosilicone seats and seals, and a maximum pressure rating of 200 psig.
Here's the fittings... to make them work with 1/2 inch fuel hose...
