1988 f250 460 cranks but wont start
Old Nov 22, 2022 | 06:48 PM
curtman's Avatar
curtman
1st Gear
Hello all! I have recently purchased a 1988 f250 with a 460 7.5 engine. The truck has dual tanks. Having trouble diagnosing crank but no start issue. I have dropped the front tank and checked fuel pump, it turns on and pumps fuel. I replaced the on rail high pressure fuel pump, still nothing. I disconnected the selector valve and cleaned it and reinstalled it, still nothing. i am getting 35 psi to the fuel rail. I am getting spark to all sparkplugs. It has a new distributor and new plug wires. i made sure that all the wires are going to the right plugs. I made sure that the timing is right. The truck cranks but will not start. Truck tries to start if i spray carb cleaner down the intake but not on its own. I am really at a loss after all of the troubleshooting i have done. Any help would be much appreciated.
Old Nov 22, 2022 | 08:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Sounds like the injectors are not working. Test with a noid light.
Old Nov 23, 2022 | 07:07 AM
Roady1269's Avatar
Roady1269
What is a noid light?
Old Nov 23, 2022 | 07:42 AM
toolman60's Avatar
toolman60
A noid light flashes on and off with the pulses from the PCM
Old Nov 23, 2022 | 07:51 AM
My4Fordtrucks
Plug the light into the injector harness to see if the computer is sending the signal to “fire” the injector.
