1991 F150 AOD Transmission Swap to 1995 AOD
Old Nov 22, 2022 | 05:57 PM
Jbremenek's Avatar
Jbremenek
2nd Gear
The AOD transmission (PRN(D)D1) in my 1991 F150 Reg Cab LB 5.0L is slipping. I found a AOD (PRN(D)21) from a 1995 F150 Reg Cab LB 5.0L. Will this work? Or, is the 1995 an Electronic transmission that I don't have the plug for on my 1991? If it won't work, what are my options besides spending $2k on a rebuild that is more than the value of the truck?
Old Nov 22, 2022 | 06:07 PM
Conanski's Avatar
Conanski
No, the '95 has a 4r70w or E4OD trans which are computer controlled. You need another mechanical AOD, a rebuild, or swap to a manual trans.
Old Nov 22, 2022 | 08:57 PM
Jbremenek's Avatar
Jbremenek
2nd Gear
What is the last year for the mechanical AOD?
Old Nov 22, 2022 | 11:16 PM
85e150's Avatar
85e150
See post 5. '88 to '93 from a truck or from behind a V8 are the preferred ones. Ford fiddled with this transmission all the way through it's life and the later the box, the more fixes and improvements were applied.
Old Nov 23, 2022 | 07:51 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Slipping when? 1-2-3 gears? If so, you probably have a dying forward clutch pack. Typical AOD failure due to the apply and release of those tiny forward clutches when it shuffles in and out of OD, this is why I say only use OD for extended freeway driving. The 4-3 and especially the 4-2 downshift is especially hard on this unit.
IMO, find someone with a core from a truck and rebuild the thing yourself. It is beyond easy. Upgrade to the 2" OD band (need the matching drum), use a minimum of 'B' code servo (I prefer the billet one from Superior), extra direct clutch, extra intermediate, extra forward, nice external cooler, pan with a drain plug, and a good mild shift kit. Superior's or Transgo's. Fresh converter. I bet you could have this done for $700 at the most.
A junkyard pullout is a fools errand unless you know it was just rebuilt. The average driver does not know how the unit works internally and the unit suffers abuse by accident.
