Ford and GM to void warranty if over payload
Old Nov 17, 2022 | 04:52 PM
last5oh_302's Avatar
last5oh_302
Was just watching a video claiming Ford and GM are going to void the warranty if you go over on payload. The new trucks have scales built into them, so they know.
I did a search for any news on this but couldn't find it, but I believe it.
This will make those numbers on the inside of the driver's door more important for many.
Old Nov 17, 2022 | 04:56 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Haha! Reason #.... well, I forgot how many... but yet another reason why I'm glad I have my 22 and don't have to worry about getting a 23!
Old Nov 17, 2022 | 04:59 PM
superduty6's Avatar
superduty6
In light of this recent rear axle recall I suspect this is correct.
seijirou's Avatar
seijirou
I suppose they could but that sounds like speculation.
That said, show me one business owner who thinks it's reasonable that they should warranty abused equipment. It wouldn't put me off if they did do this. Stick to the designed capacity. Rent bigger if needed occasionally, buy bigger if needed regularly.
Old Nov 17, 2022 | 05:01 PM
last5oh_302
It's not speculation when the truck is watching and recording your every move. Big brother is watching.
I mean maybe you could get away with it you can prove the built in scales aren't calibrated properly? Good luck with that.
Old Nov 17, 2022 | 05:05 PM
seijirou's Avatar
seijirou
You know it's recording, or are you speculating?
Old Nov 17, 2022 | 05:08 PM
#1bigmark's Avatar
#1bigmark
Temporarily Deactivated
I know Ford is doing that built in scale thing but I didn’t see that as being a thing for the GM trucks.
I don’t see myself going over 3,520 ever so
Old Nov 17, 2022 | 05:11 PM
Split rims's Avatar
Split rims
I would void the warranty too.
Old Nov 17, 2022 | 05:12 PM
Keokie's Avatar
Keokie
Well, maybe. But current laws require the manufacturer has to prove your misuse caused the problem. For example, a crushed axle tube would have a strong argument, but a leaking rear main seal would not. So, exceeding payload in and of itself could not likely 'void your warranty' legally.
Also, I'm not sure how hard it will be to defeat the scale; pull the fuse, disconnect a lead, etc.
The manufacturer's motivation to do so would be significant if their info tells them exceeding payload is costing them. If it doesn't, the Marketing Department would certainly campaign against it, as it could definitely impact sales.
I guess we will see...
Old Nov 17, 2022 | 05:15 PM
last5oh_302
Ford can't speculate, if they are indeed going this route.
Old Nov 17, 2022 | 05:25 PM
last5oh_302
This is the video. He said they'll void the warranty if the truck goes over the MGVWR, which would likely put it over payload as well, so my mistake on the title of this thread. It's MGVWR, not payload.
Old Nov 17, 2022 | 05:31 PM
Dsmoto32's Avatar
Dsmoto32
This is one of the things I was afraid of.... which led me to get a DRW, so I don't have to essentially ever worry about exceeding max payload.
The only thing that I'm thinking is not all the 23's will have the onboard scale? From what I heard, that is an option on Job 2 and Higher Trims? Pretty sure my ordered Lariat won't have onboard scales. I wouldn't be surprised if starting in 2024, it's a standard feature on all Super Duty's.
Old Nov 17, 2022 | 05:32 PM
donovan's Avatar
donovan
Well lets see the video does not provide a link to the announcements. Looks like a guy try to drive up his youtube hit counts. I calling BS. Got to learn there MORE BS on the internet then real
Old Nov 17, 2022 | 05:35 PM
Dsmoto32's Avatar
Dsmoto32
https://www.youtube.com/watch?v=bc313TkfzEY
Max Gross Vehicle Weight Rating and Available Payload is essentially the same thing. Max Payload IS Max Gross Vehicle Weight Rating
Old Nov 17, 2022 | 05:37 PM
last5oh_302
True enough!
