96 F 150 running lights are out
Old Jun 16, 2022 | 10:26 AM
Dangudov's Avatar
Dangudov
1st Gear
I have a 96'F150 with a 5.0 engine.
The rear running lights aren't working.Recently replaced the ignition, alternator and the starter. Checked all the fuses. Any suggestions welcome.
Old Jun 16, 2022 | 12:33 PM
Mudsport96's Avatar
Mudsport96
If the rear wiring looks okay, pull the headlight switch out of the dash and inspect. I may be starting to melt... yes they do that sometimes
Old Jun 16, 2022 | 04:53 PM
AuroraGirl's Avatar
AuroraGirl
stop replacing parts randomly
Also, do you have a trailer plug on the back of your truck, if not mounted it may be wrapped up behind bumper. if you have a receiver tube for a hitch then i would definitely check. also do you have any relays under the hood hanging on the side of the fuse box? they would be 2 of them with a plastic cover over both. or a trans cooler in front of your condensor in the corner closest to the battery (ish) OR do you have a trailer brake controller under dash by your legs or feet?
Earn88fan
Sep 7, 2021 07:59 AM
stroker870
Aug 31, 2009 04:01 PM
storminc
1978 - 1996 Big Bronco
Aug 12, 2002 08:31 AM
