TTB swap 1991 f150/f250hd d44 to d50
Old Jun 15, 2022 | 10:28 AM
Stuccoman's Avatar
Stuccoman
1st Gear
I'm putting a d50 ttb or replacing the d44 ttb coil to d50 leaf any one help me out on this thank you never done this
Old Jun 15, 2022 | 01:53 PM
JJF20's Avatar
JJF20
I’d do a Google search on that topic first, not sure what your reasons for swapping are, but here’s a few threads to read up on…
https://www.fullsizebronco.com/threa...tb-d50.105677/
https://www.ford-trucks.com/forums/1...le-shafts.html
https://www.ford-trucks.com/forums/1...-half-ton.html
Old Jun 15, 2022 | 02:32 PM
chappys4life's Avatar
chappys4life
Dont! It is a horrible ride
Old Jun 15, 2022 | 04:23 PM
GoinBoarding's Avatar
GoinBoarding
What is the goal here? Most go the other way: leaf springs to coils.
I put a D50 third member in my D44 beams, used the bigger inner shaft on the passenger side (bigger slip yoke & 1350 series U-joint), and upgraded the rest of the shafts to chromoly. I can romp on it pretty good with no failures on 33" MT tires and loaded to GVWR. But still have the good ride of coils and more travel than I know what to do with. Couldn't pay me to swap to leaf springs up front!
Old Jun 16, 2022 | 12:29 AM
Stuccoman's Avatar
Stuccoman
1st Gear
​​​​​​ I had a bad rear so I found the same year truck only f250 hd I paid 300 for both I put the 10.25 In so I have 8x6.5 wheels in the rear and adapters for the front the front end is pretty beat it needs gone through. I have had to do a lot of work on this truck it was beat on and never any kind of maintenance so I figured o might as well put the front in that came out of the same truck.that is my reason I have new leaf springs for the front .I was going to say at coil but the 50 is leaf and I feel it's held together better , I have it so I might as well .I do have a d50 lor 60 straight not sure witch it came out of 99 f250 but it needs gone through it's missing all steering and rotors I feel it's easier and cheaper to go with the ifs and I don't know what I'm doing so it seems easier to go that way .I appreciate y'all's input and I'm open minded to hear ya know .
CurleyBeard
Mar 14, 2020 09:11 AM
Edgethis
1978 - 1996 Big Bronco
18
Nov 15, 2017 01:14 PM
Dunnrightmobile
Jan 21, 2012 02:39 PM
tbirdage
Offroad & 4x4
28
Feb 2, 2011 04:17 PM
Fordtruc526
Jan 14, 2005 03:23 AM
