Oil Pressure Sender vs Oil Pressure Switch - a little help!
Any leads to purchasing correct sending unit are appreciated as well. Thanks all!
If you're going to keep the pressure light, if one is not already there, you'll need to add another wire for the temp sender.
The pressure sender is basically a variable resistor that has one side already connected to ground (via it's outer pipe, or straight-thread body screwed into the block)
If you were to "short" the pressure sender wire to ground, the gage would go the full scale. Same with the pressure switch for the light. It simply goes to ground below a certain pressure (usually around 3-10 psi depending on the switch) The actual oil pressure light always has (ign switched) 12V on one side and the other side connected to the sender which completes the circuit to ground until the engine produces enough pressure to open the switch.
So in a nutshell, you need an additional wire for a gage to connect to the gage sender assuming you still want the light to work. If you don't want to continue using the light, then use that wire for the gage. If it's me, I would use both and I'd also add a piezoelectric buzzer/beeper to the light circuit to make a loud enough noise to get your attention in the event of oil pressure loss (and you don't immediately notice the light)
https://www.murata.com/en-us/products/sound/sounder
By the way, I think I still have the original temp sender for my 55 if you want it.
Cheers,
Rick
Cheers,
Rick
Copy on the wiring - sounds like I am good to go as my truck came with a oil light, and I'm just installing an oil gauge in its place. I do still need to find the oil gauge sender - I have three of the oil light senders.... If it would ever stop snowing here I might actually get some work done on the old truck.
