Turn Signal Switch TSS diagram?
Old Jan 21, 2022 | 09:39 PM
654x4's Avatar
654x4
Does anyone have a diagram or troubleshooting chart for this switch? I have a 65 F250 4x4 and the wire colors do not seem to match the 65 wiring diagram I have found online. I just want to be able to ohm the switch and determine if it is the switch that is bad or possible corroded wiring connections. I had right side turns signals last week, now when I hit the right signal just the front right indicator comes on, but does not flash. Thanks
Old Jan 21, 2022 | 09:49 PM
Christmas's Avatar
Christmas
you need one of these.
1965 FORD F100-F750 TRUCK WIRING MANUAL | eBay
Old Jan 21, 2022 | 09:54 PM
Christmas's Avatar
Christmas
This will get you going.
Old Jan 21, 2022 | 10:25 PM
654x4's Avatar
654x4
A cursory search under the dash looks like I have 3 different connections from the TSS. That photo shows 2. Mine appears to have 2 3 wire to 3 wire junctions and a 1-1 junction.
Old Jan 21, 2022 | 10:35 PM
Christmas's Avatar
Christmas
No matter the connector count do the wire colors match up. IMO the problem is more than likely the TSS. I assume your wheel is off. Try powering the system in each position and pushing down on the switch and see if things change.
Old Jan 21, 2022 | 10:39 PM
654x4's Avatar
654x4
I was going to pull the wheel in the morning. Just checked it out this evening. I had issues with my wiper switch and I was able to disassemble and get working. I am hoping to do the same with the TSS>
Old Jan 22, 2022 | 12:22 AM
66F250_4x4's Avatar
66F250_4x4
Looks like you have this. I believe particular to 4x4 and the four spoke wheel. Horn contact geometry is different. Look for 4x4 wiring diagram if need be. Though colors might be same as noted. New TSS of this style is rare. Not reproduced. Be careful with it.
Old Jan 22, 2022 | 05:31 AM
654x4's Avatar
654x4
Yes, those are the connectors I have
Old Jan 22, 2022 | 08:25 AM
654x4's Avatar
654x4
Mine were stuck, I used a hair dryer to heat them up and was able to get them apart without breaking anything. I checked them at the connectors and the left side is not working. All the lights work when the switch is pulled out completely. I will examine the switch, but I think I will probably have to track one down. Any idea how to remove the horn button on the 4wd 18" wheel? It just spins left when I push it down and turn ccw
Old Jan 22, 2022 | 10:17 AM
654x4's Avatar
654x4
I tried and tried but ended up breaking the horn button. I could not get it out at all, I hope I can find a replacement. Imagine how shocked I was to find several mud dauber nests, acorns and a family of dead yellow jackets beside my TSS. I used a shop vac to clean it out then hit the switch with some contact cleaner and worked it back and forth a few times. Bingo!! I now have functioning blinkers on both sides. I think I will use this cleaner on all the dash connections.
Old Jan 22, 2022 | 01:35 PM
KO1960's Avatar
KO1960
There's your problem. Nuts and honey.
Old Jan 22, 2022 | 03:25 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
If this is the one you need - and I think it is - better snag it quick:
https://www.ebay.com/itm/14424796108...kAAOSwd-phaUJJ
Old Jan 22, 2022 | 04:33 PM
654x4's Avatar
654x4
I think I need the C2TZ-13341-D. This one is working but if I shake it the light flickers
Old Jan 22, 2022 | 04:37 PM
ibuzzard's Avatar
ibuzzard
In that case, here you go. (If these are that hard to find, the time to buy a spare is yesterday):
https://www.ebay.com/itm/17512179150...8AAOSws7hh6yLE
Old Jan 22, 2022 | 05:10 PM
654x4's Avatar
654x4
Thank you!!! It is on the way to my house. Hopefully this one will last me a bit.
