1965 F-250 3/4 Ton Estate Sale Purchase
Picture of Estate Sale:
I ended up purchasing the black one.
In it's lifetime, the truck worked for a carnival for quite a few years, making sure they got from destination to destination, and was owned by a mechanic who used the truck as his daily driver during normal business operations.
According to the owner's son, he put a 390 into the truck, before later replacing it with a 428 from a 76'. That old 428 engine was on search & rescue missions, like when St. Helens blew.
Here's a photo of the truck on it's way to my place.
The next day, the truck was in my front parking lot.
The first thing I did was clean out the interior.
I can about guarantee you don't have a 428. Sorry. They never came in trucks, and weren't made after 1970. Even then they were a rare, hi performance option only found in Mustangs and Torinos after '68, and was a rare option in T-birds and Galaxies between 66 and 68. If he said it came out of a 76, he would have to mean a truck (the FE engine was phased out of cars in 1969, other than Mustangs for '70), so it's most likely a 360, maybe a 390, but for sure not a 428. fyi.
I have the same truck but a 4x4. I am a few months ahead of you on my project. You can get the shop manuals on Ebay, I think mine were around $65 for a 3 volume set. This will provide answers to most of your questions. The fuel tanks are readily available online from Rock Auto, Dennis Carpenter, LMC or many other online retailers.
The fuel pump is located on the front of the block on the driver's side. It should have a line coming from the frame going into it and a line going to the carburetor coming out of it. It is a mechanical unit. A standard replacement master cylinder is a single pot, I used a double 50/50 pot off a newer F350 that had the same bore size.
Welcome to the Forum. On the gas tank it looks like someone filled the original filler neck location behind the drivers door handle. Personally I like my "in cab" tank but in your case it may be easier to put one between the frame rails in the rear. A lot of people go with a Mustang tank. Since you have the fuel door already in the side of the bed that may be the way to go, or just cut out the OG location. Since you are in OR, a "local" contact that would be useful is "Slick Truck Parts" down near Eugene. Brian Morrison has a good selection of parts for the "Slick" year trucks.... 61-66. https://www.facebook.com/slicktruckparts/ He is very knowledgeable as well. I am in So Oregon and have spoken to Brian a lot on my needs. As other's have said. Dennis Carpenter, Mac's Auto Parts, Carolina Classics, Steele Rubber Products and others are good reputable places... Sometimes CJ Pony Part and LMC... Sometimes people have issues with their parts or service.
I just picked up that automatic flexplate inspection cover for my '64 F250 with an FMX on eBay from a company in Albany... They have another one available.... I'm not sure if the C6 and the FMX take the same cover but I think they are close. Others here will straighten me out on that....
https://www.ebay.com/itm/23406015548...MAAOSwAoFbba3uAnother good resource is Sid Drapal of https://droppedaxles.com I picked up a lot of things to lower my '62 Unibody but he also does I beams and disc brakes for 3/4 ton trucks. The choices of aftermarket discs for the 3/4 ton are few. You can use some newer F Series part and convert.. Not as easy on my '64 straight axle. He has a lot of stuff that is not on the website. Best to call them.
Great project! Seems like you are having fun with it... Keep it up and keep posting photos!
I am not sure how it was put in gear from the pictures. I cant see the spot where the shift arm would have gone. Does it have the clutch pedal cut off or can you tell if it was removed?
I think, if it was manual, and changed to auto, and not done correctly, you may need a neutral safety switch on the column for the reverse lights. But others are better at that than me. I did have this exact problem with my 75 i bought.
It looks like you need some small stuff like horn button, acc pedal, signal switch, hood ornament, doo access panel, c-6 transmission access cover, etc. email me me if you dont have them. chircolandinc@gmail.com
C&G Ford Parts (cgfordparts.com)
You need to get a shop manual they are available on CD, USB, and print. The originals turn up on e-bay a lot but don't overpay for one.
Now the fun part. I'm sure you want to see if it will run. Since there is no obvious shifter in those pictures. You need to make sure that thing is in park before you turn the key or there could be injury or death involved.
I would pull the plugs and squirt in some of your favorite lubricant. Since the 428's and 410's had the longest stroke of all the FE's 3.98 inches. You can bring a piston to top dead center, stick a dowel in there and mark it, turn it to bottom center and mark it. Measure the distance between the marks. 352/360= 3.5 inches, 390/427=3.78 inches, 410/428= 3.98 inches.
If that transmission is a C6 and it was transplanted along with the engine it could be a good one. Look on the passenger side for the servo. It may still have a tag on it that will identify the trans. Also, the servo cover like the one laying on the table in the picture will have a letter cast into it. That letter can be a good clue as to what in that trans.
