292 or 312 whats the best choice
Old Dec 13, 2021 | 08:01 PM
buck5050's Avatar
buck5050
Working on a 62 f350 4 speed drw Napco AWD came with a 292 2bbl. If I rebuild an engine and want a little extra power should I use a 312 from a 62 Tbird that I can get for roughly 4 to 500 dollars , or stick with the 292? Im planning on 30 over bore , mild cam, headers , and any other suggestions that you all have would be greatly appreciated. thank you
Old Dec 14, 2021 | 07:26 AM
hiball3985's Avatar
hiball3985
312 in a 62 TBird?
Old Dec 14, 2021 | 08:05 AM
buck5050's Avatar
buck5050
Yes correct
Old Dec 14, 2021 | 09:55 AM
buck5050's Avatar
buck5050
Also wondering for this application ? Can I run a 12 inch big truck clutch and pressure plate?? Will I need to index and drill the flywheel ?
Old Dec 14, 2021 | 04:17 PM
charliemccraney's Avatar
charliemccraney
A 312 in a '62 T-Bird will have been swapped. You will want to check the block numbers and possibly pull the oil pan to verify.
Everything else equal, for a mild build, the 312 will produce more power but it will be more expensive because of the larger main size, and therefore, the bearings and rear main seal required. 312s also have issues with cam tunnel alignment, which can be expensive to correct.
If you want to take it up a notch, you can machine the 312 crank to fit the 292 block. That gives the same stroke but should produce even more power due to the reduced friction of smaller diameter journals than an otherwise equal 312.
You can get 300hp out of a 292 pretty easily so you will probably be happy with the 292.
Old Dec 14, 2021 | 06:00 PM
buck5050's Avatar
buck5050
Since cost is a factor I think we will retain the 292 and do what we can with it. Thanks Y blocks are certainly not in my wheelhouse , appreciate your input.
Old Dec 22, 2021 | 06:20 PM
idaho211's Avatar
idaho211
62
62 heads are low compression heads. ECZ-G heads have bigger valves and a smaller compression chamber increasing compression. Be aware composite head gaskets can lower compression as well. I like the stock ford barrel intake and either ford ram horns or sanderson headers for exhaust. They flow better than the stock cross over.
Old Dec 23, 2021 | 10:27 PM
buck5050's Avatar
buck5050
Thanks will be doing home work as the 292 gets torn down . Im not sure I will have headers option with the napco front axle . Can someone recommend a distributor for this application?
Old Dec 24, 2021 | 01:21 AM
idaho211's Avatar
idaho211
John Mummert of Ford Y block makes some good ram horns. They should fit even with the Napco front end.
Old Dec 24, 2021 | 06:34 AM
charliemccraney
Rebuild the '62 distributor but best is to use a brand new distributor. MSD, Petronix, and a Chinese copy of MSD are the options for that.
Old Jan 16, 2022 | 09:18 AM
buck5050's Avatar
buck5050
A few folks have mentioned to me that water pumps are difficult to find . What is a good source to find a quality rebuilt water pump? As I am removing the engine it looks like the the paint color of the Y block was dark blue ,is that correct for 62 ? To aid the cooling of the rebuilt engine should I go to a 6blade fan ? Thanks for your help
Old Jan 16, 2022 | 02:56 PM
charliemccraney
Truck pumps can only be found as rebuilds, and realistically, you sill probably have to send yours out for rebuild. I have no suggestions for that.
You can use a car pump IF you also use a car pulley
Old Jan 16, 2022 | 05:37 PM
buck5050's Avatar
buck5050
Thank you , not finding anything searching carpenter , macs etc . Will check our local NAPA tomorrow . THANK YOU !!!! Appreciate your help
Old Jan 16, 2022 | 06:47 PM
charliemccraney
Check the shaft diameter. Truck is 3/4". Car is 5/8" It's possible yours has either had the pump or engine swapped by now.
Old Jan 17, 2022 | 01:14 PM
buck5050's Avatar
buck5050
Will do . This is my first experience with a Y block rebuild, so much to learn here.
