Need 46-47 Front Shock Bracket and Front Suspension Diagram
Old Dec 8, 2021 | 12:14 PM
tsmithbonterra's Avatar
tsmithbonterra
Hi-
My mechanic has my shop manual. Anyone have a drawing of the front suspension for a 46-47 1/2 Ton Pickup they could share. Much appreciated.
I also need the bracket that the front shocks attach to. I only have one and need the other. Attached photo shows what I need.
I'm in Southern California.
Thanks, Tom
Old Dec 9, 2021 | 12:57 PM
Rust Wrangler's Avatar
Rust Wrangler
Your shock bracket is a conversion piece to replace the factory Houdaille shocks, on the cars. They bolted up to the frame, in place of the original shock. To make them work on the trucks the inner fender needs to be modified for clearance. There was two different lengths available, so check that when you locate some. They pop up from time to time. Seems I've seen them available from one of the parts venders but, don't recall where.
Old Dec 10, 2021 | 09:54 AM
tsmithbonterra
Thanks Rust Wrangler. Very helpful info and diagram. Can you share a diagram of where the stock shocks connect up in the front suspention?
Thanks!
Old Dec 10, 2021 | 04:47 PM
Rust Wrangler
Old Dec 10, 2021 | 06:53 PM
tsmithbonterra
Thanks. That quite a set up!
BigRedTruck9000
Sep 18, 2023 11:57 AM
Ford ST
Aug 13, 2019 12:15 AM
red-bulli-69
Aug 12, 2019 04:26 AM
berto
1997 - 2003 F150
Jul 16, 2006 12:34 AM
Herby
Jul 19, 1999 01:51 PM
