2004 f350 SD 6.8l triton v10
I have a fairly significant oil leak somewhere around the component where the lower radiator hose connect. Not 100% sure thats where it's coming from but want to identify the components name or other components above it that may be leaking. Hard to see where the actual leak is coming from but thought if I could look at the breakdown then I could order what I need to fix before I remove a bunch of components to fix the problem. Any help is much appreciated. FYI I have bought a Haynes manual but it's very vague on many pictures of where my problem is.. Thanks in Advance, Steve
When you say lower radiator hose...are you talking about where the 2 smaller lines run back towards the oil filter (they connect to the oil cooler). Or are you talking about the large diameter hose where it attaches to the engine block?
