1991 F150 Clutch Noise
Old Jul 6, 2000 | 05:25 AM
TallPaul's Avatar
TallPaul
Old Jul 6, 2000 | 09:58 AM
warthawg0's Avatar
warthawg0
I have a 1991 F150 Straight 6 with 105k miles and a 4 speed manual. I have just started to hear what I believe is chatter. It does not make a sound in neutral or when in 4th gear. The sound starts just when the clutch is depressed and contains until in neutral or 4th gear. Any help on where to began looking?
Old Jul 6, 2000 | 11:14 PM
PAUL_2's Avatar
PAUL_2
I would suspect the throw out bearing is the cause of the noise . When you depress the clutch pedal the T/O bearing is taking the full force of the pressure plate and if its getting bad it will make a noise .
Paul
