Body Lift on a '91 F-150
Old Jul 13, 2000 | 01:04 AM
Josh00's Avatar
Josh00
I want to put a 2-3" lift on my 2wd '91 F-150 and since I cant afford a suspension lift, I plan to go with a body lift instead, but first I wanted to know how the front end is raised since, from what I understand, it is illegal to use lifting blocks on the front end of a vehicle.
Old Jul 13, 2000 | 08:41 AM
Chuck P.'s Avatar
Chuck P.
[font size="1" color="#FF0000"]LAST EDITED ON 13-Jul-00 AT 09:44 AM (EST)[/font][p]When they speak of lift blocks in the front, they are refering to a leaf spring suspension system. NEVER EVER use blocks under the front leaf springs-it will spit them out due to the leverage placed on them by turning. The lift is done with spacers that go between the frame and body. As far as the body lift, be sure you know what is involved. Some things go up and other do not. Some that go up are the radiator and shroud, brake booster and master cylinder, heater core and a/c condensor, steering column ect., the things that don't go up, anything that is attatched to the frame- tranny lines, wiring harnesses, engine/trans/transfer case. In almost all these cases, mods will have to be done to relocate, lenghten or cut to make sure nothing hits and everything works as it should (fan will hit at the bottom of the shroud, hoses may not quite make it to the radiator, shifter may not have enough room to shift correctly without hitting the body ect, ect.) So in closing, just make sure you know what it will take to lift this way-that way you won't get any nasty surprises along the way! Good luck with your project!
Old Jul 13, 2000 | 06:31 PM
Pastmaster's Avatar
Pastmaster
