Wiring a 4 flat connector
Old Jul 4, 2021 | 11:05 AM
ChevyExterminator's Avatar
ChevyExterminator
I had originally posted this to the towing section, but nobody responded.
In about a week I am going to have to use a 6x10 trailer to move my brother into his new house. The trailer has a 4 flat connector, and so I need to wire up a 4 flat plug to my truck. Just wondering where to find each of these wires, which ones to use, and maybe some pictures. I have the plug that I need to wire in, and I know what each of the colors go to, just where they are I am not sure. I know the brake light socket has like 3 wires going into them.
Thanks!
Old Jul 4, 2021 | 11:52 AM
DB429SCJ's Avatar
DB429SCJ
These work good, you don't have to cut any wires .https://www.suspensionconnection.com...iring-kit.html
Old Jul 4, 2021 | 11:54 AM
ChevyExterminator
Im fine with cutting wires and such, just the location I am confused about.
Old Jul 4, 2021 | 12:05 PM
mudbogger2's Avatar
mudbogger2
Those connectors are the best way to go unless you have weather proof wiring connectors to wire in a plain one. That connector is in the frame under the driver tail light.
Old Jul 4, 2021 | 07:37 PM
5851a's Avatar
5851a
I have used those connectors mentioned. Easy as can be, highly recommend, Unplug, plug back in and done.
Old Jul 4, 2021 | 10:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on locate a plug and play harness. Or locate behind taillights, unplug, plug in and plug back in. Like a inline connection.
https://www.etrailer.com/Custom-Fit-...ID=19791171987
Old Jul 5, 2021 | 09:24 AM
FuzzFace2's Avatar
FuzzFace2
NO DONT GO CUTTING WIRES!
You are now making a place for weather to get in and eat at the connection to the point where you have no tail lights and wonder why.
Just spend the $20 and get the Tee wire connection and as said un-plug, plug in the Tee and done.
Spend the rest of the time enjoying a cold one (or more )
BTW my parts truck came with that Tee and I used it to wire up my 7 pin connector, trailer brakes & power to charge a battery, and was the best thing I have ever done.
I also picked up a 7 pin to 4 flat adapter for the smaller trailers.
Dave ----
Old Jul 5, 2021 | 10:57 AM
ChevyExterminator
Just ordered one off amazon, much easier.
Old Jul 5, 2021 | 11:32 AM
77&79F250's Avatar
77&79F250
And then adapting a round small 6 or a big round 7 into the mix is next. And then you need to wire in a brake controller.
Old Jul 5, 2021 | 12:17 PM
5851a's Avatar
5851a
I used the plug in adapter to wire my 7 pin to avoid cutting wires, then added the brake and hot wire. Just use a 7 to 4 plug in for times with 4 flat..
Vinford
All Things Towing
Jan 11, 2014 12:50 AM
DetailerDave
All Things Towing
28
Sep 18, 2013 01:09 PM
ekeller
Mar 17, 2005 02:57 PM
ccrider966
Sep 9, 2004 08:22 AM
Tim Ervin
1997 - 2003 F150
Nov 1, 2003 08:18 AM
