2017 6.7 transmission cooler dumb question
Old Apr 29, 2021 | 03:25 PM
Matt Pace's Avatar
Matt Pace
I'll admit I didn't look which I'm now shocked at myself but do all 6.7l powerstroke have transmission coolers? This one is a xl so pretty basic. It did have the trailer brake controller so I'm certain it does but now I'm second guessing myself.
I can't imagine any powerstroke not having one but now I'm a little concerned.
Thanks in advance!
Old Apr 29, 2021 | 03:36 PM
ford390gashog's Avatar
ford390gashog
All were equipped with it.
Old Apr 30, 2021 | 05:24 AM
senix's Avatar
senix
In front of the transmission.
Old Apr 30, 2021 | 10:13 AM
Overkill2's Avatar
Overkill2
Thanks in advance!
Check out that 2nd video I posted on fritz's video thread. That guy Don does a trans flush and disconnects the return line from the cooler. It's on the passenger side I believe.
Old Apr 30, 2021 | 11:03 AM
Matt Pace's Avatar
Matt Pace
I did a transmission flush on my old Chevy 5.3 so I'm kind of familiar with that process. They are fixing the upper oil pan so I'm wondering if the transmission fluid is going to be replaced with that process. I thought I read somewhere that the transmission has to be removed to get to it but I'm still learning and figuring out this whole new world.
Old May 1, 2021 | 07:02 AM
dirthawg's Avatar
dirthawg
Yes trans is removed for upper oil pan repair and fluid draining is not required. They may add a little fluid once it's back in due to fluid loss when disconnecting the cooler lines but that's about it.
There was never a line item for trans fluid on either of the repairs I had done. Coolant in the primary system does get replaced.
Old May 1, 2021 | 10:37 AM
Matt Pace's Avatar
Matt Pace
Oh ok, I figured it had to be swapped by the sound of it. I'll just plan on doing a fluid swap and filter change.
celjel
Feb 12, 2010 12:28 PM
BigD7575
Jul 25, 2008 07:10 PM
LongJim
May 11, 2007 08:12 PM
hookspacken
Apr 18, 2003 04:32 PM
