Use sealant on pinion seal?
Old Mar 22, 2021 | 06:48 PM
gogoat's Avatar
gogoat
I'm replacing pinion seal in my stock 49 F1 rear. Should I use sealant on outer rim of seal?
Old Mar 22, 2021 | 10:30 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I haven't put one in the stock rear diff but, I typically put a slight film of sealer on any seals that are bare metal. Especially if the bore is not perfect. I don't put it on seals that have a rubber coating or has the bead of sealer applied from the manufacturer. JMO.
Old Mar 23, 2021 | 12:14 PM
rusty48's Avatar
rusty48
I replaced mine last year, stock rear end. I did not use sealer. Maybe I did a good job or more likely got lucky?
Old Mar 23, 2021 | 01:02 PM
52'F-3's Avatar
52'F-3
I use a little "Permatex Ultra" on outer edge of sealing area in pinion housing if using a cheap seal, or it has any small damages or scratches. if I'm using a "National" brand seal, I don't. It comes with something similar to a ring of dried sealant.
also as added insurance I put some sealant on splines inside the driveshaft yoke. I've see gear oil leak out splines and from under nut a couple times
Old Mar 23, 2021 | 01:17 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Put sealer of your preference (I use aviation form a gasket) on the outside metal portion and don't forget to put grease on the lip portion of the seal where the pinion goes in. This prevents dry metal of the pinion from eating the rubber seal.
thundersnow70
Sep 3, 2020 08:12 AM
3twinridges
Aug 10, 2020 02:23 PM
Ryanalofs
Mar 24, 2020 07:04 PM
Powerstoke73
Aug 16, 2014 07:54 AM
BR F1
Aug 9, 2009 06:51 PM
