Front Dana 60. Yes or No
Old Jan 27, 2021 | 06:58 PM
black & blue 78/9's Avatar
black & blue 78/9
Front Dana 60. Update .
My local jy has a 6/79 F250 that has dana 60's front and rear. Gearing is 3.54. They will pull them for $1500 for BOTH.
Front, I get the front spring mount, leaves, axle, complete sway bar with end links, rotors, calipers and recently installed brake flex lines and stock lockouts. Not aftermarket.
Rear, drum to drum, factory rear blocks.
Probably a dumb question, but should I buy these with 3.54 gearing? I think yes. Will this gearing be prohibitive to using 37" and bigger. I might just sell it to.
Old Jan 27, 2021 | 07:28 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Now days $1200 to 1500 for just the front axle is the going rate in my neck of the woods, thanks to rock bouncers and jeep guys doing upgrades.
Old Jan 27, 2021 | 07:39 PM
ford390gashog's Avatar
ford390gashog
Well the front axle is worth over 2k here, the rear axle isn't worth much.
Old Jan 27, 2021 | 08:14 PM
black & blue 78/9
Thanks guys.
Should I be concerned about the 3.54 gearing? Or just screw the gears and buy it anyways?
Old Jan 27, 2021 | 08:23 PM
440 sixpack's Avatar
440 sixpack
If you have any power at all 3.54's would be great. 37's are stupidly big but they should still work fine.
I have 33's and I just went to a lot of expense to put an overdrive in. I still wish I had 3.54's .
Old Jan 27, 2021 | 11:50 PM
maddogjohnson's Avatar
maddogjohnson
If that is a high pinion dana 60 it is an absolute no brainer to buy all of that for $1,500. 3.54 gears be darned. It's a good deal that you can easily make money off of, use as is, or regear if you have other needs.
Old Jan 28, 2021 | 07:56 AM
somethingclever's Avatar
somethingclever
I like 3.55's with any original trans...with 35" or 37" tires.
In fact I prefer it over 4.10 gearing...
Old Jan 31, 2021 | 08:48 AM
tabascom16's Avatar
tabascom16
You can always buy it and then make a swap with a guy who has a D60 with 4.11s if you don't like 3.54s. If you have any sort of power adders with your engine you probably won't notice much of a difference between the gear ratios. With 35" tires at 55 mph in direct drive, it is under a 300 rpm difference.
A rear D60 is worthless. They are tinker toys.
Old Feb 4, 2021 | 12:35 AM
black & blue 78/9
Should I pass on the rear? I was thinking I should buy it to have matching ratios.
I will be buying front axle, rotors, calipers, sway bar, links and clamps, leave springs still attached to the axle, front/back leave mounts, steering gear box, steering wheel, manual trans TILT steering column, shaft between column and gear box, complete rear axle ( drum to drum), factory rear block, front drive shaft, midship plastic gas tank steel surrond, Edelbrock 4bl and eddy alum intake. All for under $1k. They pull.
If I dont buy the rear axle, I would save about $250-300.
Old Feb 4, 2021 | 05:28 AM
77&79F250's Avatar
77&79F250
If I was you, I would pass on it and PM me the location. Lol If you know you are going to regear the front then why buy the rear axle, unless you need it in the 1st place.
Old Feb 4, 2021 | 07:49 AM
tabascom16's Avatar
tabascom16
There is no need to pass on the rear axle if you need it or want it. Just don't think there is any monetary value in the rear axle. They do just fine, but if you are looking to put a ton of power down you will be wanting something bigger than that D60 rear.
Old Feb 4, 2021 | 07:23 PM
somethingclever
that is about $3k worth of parts around here.
Old Feb 4, 2021 | 08:32 PM
Evan76's Avatar
Evan76
I'd buy that in a heart beat.
you can't touch a 77.5-79 hp 60 around here.
I'd probly regear to 4.54. I just did gears in my jeep (4.88)
invested in a press made a set of set bearing, some measuring tools..
probably have 10hours into taking front and rear axles apart setting pinion depth and backlash. Set up bearings are a must..
Knowing the numbers having the tools to see those numbers and shims to bring them into the ball park,, paint and repeat.
Old Feb 5, 2021 | 05:10 AM
boingk's Avatar
boingk
Do it. Can't hurt to have a spare.
- boingk
Old Feb 5, 2021 | 02:55 PM
2dwoods's Avatar
2dwoods
Do you figure someone put 60 under a 250 out of a 350. I'm sure glad listening to y'all I bought 79 f 350 for 700 bucks and stripped it sold the body and trans the guy wanted the # on the body 500 bucks so I got all my stuff for 200 I'm willing to sell for 3000 to the gentleman above, lol
