Alternator won’t charge good enough
Old Aug 1, 2020 | 11:23 PM
Josethef100's Avatar
Josethef100
Hi, I’ve been having problems with my alternator charging at only 11.8 volts and I don’t know why, I converted it to a 3g alternator hoping it would help solve my problem but it didn’t, my ground appears to be just fine since I’ve screwed with it so much and tested it. And I redid the pretty much all the wires except the “i” one and I don’t know what to do anymore. Thanks
Old Aug 1, 2020 | 11:58 PM
BobbyFord's Avatar
BobbyFord
Have the alternator tested and reevaluate your wiring.
Old Aug 2, 2020 | 12:55 AM
matthewq4b's Avatar
matthewq4b
So you replaced the reliable 1G set up with 3G and never bothered to diagnose the fault with the 1G set up.
Well what wiring diagram did go by to wire in your 3G ?
Old Aug 2, 2020 | 07:45 AM
Josethef100
Yes, it use to be a 1g and it was going strong and I had a brand new (not rebuilt) 3g that was ready to be swapped in so I figured I might as well put it to good use. I’ve checked my wiring about 10 times and it’s correct
Old Aug 2, 2020 | 09:13 AM
6t6merc's Avatar
6t6merc
The belt(s) might be slipping even though you can't hear it. The 3G needs a lot of turning force to work efficiently. Try adjusting it to a position you might think is a bit too tight.
Eric
Old Aug 2, 2020 | 11:32 AM
matthewq4b's Avatar
matthewq4b
You verified 12V on the I wire? And that the A wire is going to the same place as your B+ ?
If those are good then as 6t6 mentioned you prob have a belt slippage issue.
Old Aug 2, 2020 | 04:08 PM
Josethef100
It probably is the belt slipping cause every so often it squeales really loud, I just don’t know how to fix it because it’s as tight as I can get it
Old Aug 2, 2020 | 04:16 PM
ford390gashog's Avatar
ford390gashog
Don't follow that diagram. The yellow wire should run to the hot side of the solenoid and not connect the old A terminal.
Old Aug 2, 2020 | 04:55 PM
6t6merc's Avatar
6t6merc
Originally Posted by ford390gashog
Don't follow that diagram. The yellow wire should run to the hot side of the solenoid.
But... doesn't "B+" mean "battery positive"?
Eric
Old Aug 2, 2020 | 04:59 PM
6t6merc's Avatar
6t6merc
Are you using a two-belt pulley?
Eric
Old Aug 2, 2020 | 05:10 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Also, belts do stretch, try replacing it.
Old Aug 2, 2020 | 05:45 PM
matthewq4b's Avatar
matthewq4b
Eric
Yup that diagram is fine, one of the few that are actually wired correctly.
Old Aug 2, 2020 | 06:57 PM
Josethef100
I’m using one belt and it’s new but the bottom bracket was kind of hard to get on when installing the 3g, maybe I need a different lower bracket
Old Aug 2, 2020 | 07:21 PM
ford390gashog
Eric
Yes but there is some obvious issues in that diagram. You can't use 6ga cable, you need 4ga minimum cable and need a inline mega fuse. The A terminal shouldn’t be connected to the old A terminal it needs to go to the battery or hot side of the solenoid. The old A wire runs through the dash gauge cluster. If you apply battery voltage to the A terminal you should have full charging voltage.
Old Aug 2, 2020 | 10:22 PM
Josethef100
I’m using the same alternator to solenoid wire with new connections, 175 amp mega fuse, and the A terminal was already connected to the hot side, it’s the I which runs to the gauge cluster and the connections are good on it. At this point I’m convinced it’s the pulley slipping
