Swapping 2001 ford 4.6l v8 engines
Old Jun 18, 2020 | 07:34 PM
V8tritonBoi's Avatar
V8tritonBoi
I Have a 2001 Expedition 4.6l v8 triton. Having trouble finding a new or used Triton. Can I fit a 2001 f150 4.6l v8 in mine??
Old Jun 21, 2020 | 08:55 PM
Mini1298's Avatar
Mini1298
Yes, they are a direct fit, just need to make sure that you try to get the same vin code, there is a vin W and a vin 6. 6 is a Windsor engine, W is a Romeo engine. Essentially the same, except for timing covers, valve covers, cams and drivetrain are slightly different. My 98 expedition was a Romeo 4.6, and I couldn’t find a good used one, but bought a used Windsor 4.6, bolted straight in, ran perfect!
Old Jun 22, 2020 | 10:03 AM
V8tritonBoi
OK. Thanks
:And I also hear that I can fit a say 04' 4.6? I saw a post where someone said that the 4.6l v8 is the same from 99'-04' or somewhere around those yes.
Old Jun 23, 2020 | 09:54 PM
Mini1298's Avatar
Mini1298
The interchange is what it is, but I have seen engines from 1994 crown vics put into an F150 with the correct truck manifolds, the basic block is the same, the heads changed in 01ish to the Pi heads, and they gained a few hp, no reason any 2v 4.6, even one from a newer e-series van wouldn’t fit with the correct manifolds.
chin814
Jun 18, 2020 08:10 PM
tomfrey
2009 - 2014 F150
Nov 12, 2008 12:14 AM
