7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Name that knock? No prize for winning.
Old Jun 16, 2020 | 06:03 PM
litebulb's Avatar
litebulb
So this happens from time to time, have about 10500 miles and bought it back on March 19th. Seems to be more prevalent when started with remote start although I may just be dumb!
Old Jun 17, 2020 | 08:18 PM
DADDYFIGJAM's Avatar
DADDYFIGJAM
That's a 7.3 Gasser?? Wow. That sounds like my 05 cummins! I assume you have checked the oil?
Old Jun 22, 2020 | 10:33 PM
STX7.3's Avatar
STX7.3
Saw another post with something similar. Ford said it was the 10 speed transmission, makes some noise when cold.
Old Jun 27, 2020 | 07:59 AM
litebulb's Avatar
litebulb
It’s pretty neat sometimes, I swear it mainly does it when I remote start the truck also but I’m gonna try and pay attention to other times. It also is sluggish to start on remote start a lot of times, I know you hear the fuel system prime when the door opens so I wonder if they forgot something when programming remote start
Old Jun 27, 2020 | 07:42 PM
4RXLA's Avatar
4RXLA
Mine makes a similar noise when parked on a sloping driveway. Makes me wonder if it has anything to do with the hill start assist or some sort of transmission engagement. I have not experienced it on level ground.
Old Jan 11, 2024 | 08:41 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
https://youtu.be/RNHlTozGMW8
Is your truck still doing it?
Old Mar 30, 2024 | 06:13 PM
BobP11's Avatar
BobP11
4th Gear
Mine sees to do that the day after towin my camper. Not sure if it's related to putting thr truck in tow mode or the lad of pulling the camper. It only does it when the engne is fully cooled off after towing and until the truck warms back up.
Old Mar 31, 2024 | 09:49 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Transmission. Go lay under it and listen....sounds like marbles in the dryer.
Old Mar 31, 2024 | 01:25 PM
ssls6's Avatar
ssls6
There is a TSB for certain models. It covers a knock from the engine area caused by the power steering pulley. Your truck sounds like it has aftermarket exhaust. Could be.an exhaust leak.
Old Mar 31, 2024 | 02:54 PM
OBS460's Avatar
OBS460
There is a TSB for a knock coming from the 10r140 and one for a cracked oil pump drive gear causing a knock.
Old Apr 2, 2024 | 04:58 PM
Cragtor's Avatar
Cragtor
Trailering
Its definitely not opportunity knocking.
Old Apr 2, 2024 | 08:37 PM
leadmic's Avatar
leadmic
What year?
Flitastic
Dec 24, 2019 07:17 PM
rockcrusher 24
Apr 20, 2015 08:01 AM
Imondi
Sep 25, 2008 04:57 PM
marksbrat
General Diesel Discussion
Jan 7, 2006 01:29 PM
