2006 Expedition is continuelly blowing the Ignition Pack on Cylinder 1.
Old Jun 11, 2020 | 06:34 PM
Michael Bacon's Avatar
Michael Bacon
Unhappy 2006 Expedition is continuelly blowing the Ignition Pack on Cylinder 1.
I have a 2006 Expedition 5.4 XLT. I have replaced the #1 Ignition Pack 3 times in 3 months. I am stumped and can't find anything that might be causing this.
Old Jun 11, 2020 | 07:38 PM
Hamfisted's Avatar
Hamfisted
How's the gap on the sparkplug ? Or try a different sparkplug altogether. What brand coil are you using ?
Old Jun 12, 2020 | 01:34 AM
Michael Bacon
I am using Motorcraft Platinum plugs. No gap to set. I have replaced it 3 times as well. All new. I will post the brand coil in the morning.
Old Jun 12, 2020 | 06:24 PM
Michael Bacon
Sorry it took me a little longer than this morning. The Coil pack that I am using is from MasterPro Ignitions.
Old Jun 12, 2020 | 09:00 PM
Hamfisted's Avatar
Hamfisted
Well, you can always go back to Motorcraft and try one out. Are they ALL this MasterPro brand, and only this one cylinder is having this issue ?
Motorcraft DG511 coil at Amazon Motorcraft DG511 coil at Amazon
Old Jun 13, 2020 | 06:57 AM
projectSHO89's Avatar
projectSHO89
I guess it depends on what "blowing" the coil actually means. A simple failure, a catastrophic meltdown or blowout or what? Any fault codes?
If it's a catastrophic failure, more likely than not, you have an intermittent fault that is causing a short circuit to ground on the trigger circuit for the #1 COP. That could be a chafed or melted wire or could be a fault inside the PCM.
Old Jun 13, 2020 | 09:19 AM
alloro's Avatar
alloro
Does it come with a new spark plug boot or are you reusing the old one?
Old Jun 13, 2020 | 09:35 PM
Michael Bacon
It means they have all had a catastrophic failure. They no longer provide a spark.
Old Jun 13, 2020 | 09:36 PM
Michael Bacon
One was an Autolite, the other 2 were MasterPro.
Michael Bacon
The spark plug boot is built in and can't be removed.
Old Jun 14, 2020 | 07:55 AM
alloro's Avatar
alloro
Have you verified the spark plug gap to make sure it is correct? An incorrect gap could be straining the coil.
Old Jun 15, 2020 | 12:36 PM
Michael Bacon
As I stated above, I am using Platinum plugs, which don't have an adjustable gap. I have replaced them each time as well, just to make sure.
Old Jun 15, 2020 | 02:15 PM
projectSHO89
Go back and re-read the last part of post #6.
jrigsby
Maryland Chapter
Mar 10, 2015 09:40 AM
danny2313
Modular V8 (4.6L, 5.4L)
Jan 9, 2014 01:42 PM
kailor
Apr 6, 2008 06:09 PM
Sonoma
Nov 30, 2007 10:51 PM
