Coolant leak in the valley of my 6.7
Old Apr 27, 2020 | 06:53 PM
Andrew Hall's Avatar
Andrew Hall
I had my truck to the dealership for an a.b.s issue and suddenly created a coolant leak, the shop changed a valve for the coolant line somewhere. Anyway three weeks later I go back and now the mechanic said he was sure the head gaskets were leaking.. well is this a problem that 6.7 are known for I have only ever ran 7.3.. the mechanic never took all the air intake off and i dont know how he could have seen the top of the engine.. I have no white smoke and I dont overheat I'm getting ready to finish my egr delete this week its already been def and egr reprogrammed. Could the egr be leaking and look like as head gasket????
Old Apr 28, 2020 | 10:24 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Apr 29, 2020 | 05:14 AM
senix's Avatar
senix
Coolant in th valley of the motor usually means the coolant line to the turbo is leaking.
this was a problem for 2011-2012 model years primarily.
What year is your truck.
Old Apr 30, 2020 | 05:13 AM
Andrew Hall
2011 is the year, do I have to take the PentiumPlentium off t ok get to get the coolant line???
Old Apr 30, 2020 | 05:17 AM
senix's Avatar
senix
it is the coolant line that goes from the turbo to the motor so no removal of the turbo. will try to find a thread of the issue for you.
https://www.ford-trucks.com/forums/1353705-turbo-coolant-leak.html
specifically
post 9.
Old May 2, 2020 | 06:20 PM
Oldyella66's Avatar
Oldyella66
I once had a coolant leak into the valley on my 2012. It turned out to be the heater core hose. The heater core hose connects to the coolant hard lines just to the passenger side of the intake, above the valley. There are two O-Rings in the connector that had failed. I replaced the O-Rings and coolant leak was gone. It took me several days to track it down to that though. I checked the turbo coolant line first, but there was no leaks at those spots.
Old May 2, 2020 | 09:37 PM
Painted Horse's Avatar
Painted Horse
Like Scott said it's common for the Turbo Coolant connector to leak on 2011 trucks.
creed74
User Gallery & Picture Display
Jan 1, 2019 11:07 AM
