Axle sealant/gasket
Old Apr 21, 2020 | 04:56 PM
gmcalis's Avatar
gmcalis
Axle sealant/gasket
I have a ‘50 F3, during my first ignorant attempt to remove the rear brake drum I started by removing the axle from the hub. I know now that isn’t necessary.
Now I need to put the axle back, what sealant should I use? If Im reading the shop manual correctly it originally had a leather gasket.
Gabe
Old Apr 21, 2020 | 05:00 PM
Steve's Avatar
Steve
You could make one from paper gasket material. I'd use a thin film of non-hardening Permatex.
Old Apr 23, 2020 | 06:14 PM
gmcalis's Avatar
gmcalis
Permashield
Will this work sealing the axle to the hub?
Old Apr 24, 2020 | 10:24 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Permatex actually makes an RTV especially for gear oil. I've used the regular black stuff on differentials without problems. Their website should have all the info you need. A gasket will make it easier to pull apart next time. RTV will still work, just be a little more work to pull apart and clean off. People use RTV there often.
Old Apr 29, 2020 | 12:08 AM
Oldb's Avatar
Oldb
Permatex gear oil rtv is the best sealing product I have ever used. The down side is when you need to take it apart. Very difficult.
B
Hossrod
Nov 27, 2018 08:51 PM
katfishgr
Nov 18, 2017 08:14 AM
HouBill
Apr 13, 2010 10:26 AM
mike L
May 5, 2006 06:18 AM
