56 F100 oil pan / axel coflict
Old Apr 21, 2020 | 04:07 PM
LakesFordMan's Avatar
LakesFordMan
Hi Ford folks,
I have a 56' F100 with 61' FE 390 and Cruise-o-matic., upgraded low and forward front springs with sway new sway bar kit. What have you folks done to create more clearance between the axel and the oil pan front sump. The axel crosses the oil pan at the approx. mid-point of oil pan length. I haver seen oil pans with a front and rear sump that might work but not for the FE 390 engine, including oil pick up, dip stick, etc. Thanks ahead of time.
Old Apr 21, 2020 | 05:48 PM
KULTULZ's Avatar
KULTULZ
So a FORD 4x4 rear sump will not work you think?
Go Here - https://www.ford-trucks.com/forums/1...p-oil-pan.html
The pan you are describing is available from CANTON/MOROSO.
Let us know.
Old Apr 21, 2020 | 08:17 PM
LakesFordMan
Thanks for the info. I did locate a Canton oil pan at CJ Pony, $500 + when it's in stock. That might be my only option since I'm not a fabricator. Time for some real precise measurements. Thanks again.
Old Apr 22, 2020 | 01:43 AM
1956_F100's Avatar
1956_F100
Don't forget about clearance for the tie rod. That might create clearance issues with rear or dual sump oil pans. It's the low and forward springs that are creating an issue with a front sump oil pan. I looked at those springs for about a minute, then realized all the issues they might cause with the 390 in my 1956 F100.
bliss1
Sep 10, 2008 07:34 PM
banjopicker66
Jun 25, 2002 06:43 AM
fntaylor
Jun 24, 2002 07:15 PM
