Difference between 2020 F250 and F350.
So if we can compare apples with apples,
let’s say both vehicles are going to have the new 7.3 gas engine. And 4 WD. 10
speed.
1. What will be the difference in the transmission, axles, and leafs, if any?
2. Any other differences?
Separate question.
I see online when building an F250, Ford won’t allow the extra heavy duty towing package unless you order the diesel. Could you get that package if you ordered thru the dealer?
speed.
Separate question.
1a. Both will get the same new HD 10-speed transmission
1b. I don’t know for sure which rear axle (Ford Sterling or Dana). This 2020 F250 7.3 appears to have a Ford Sterling rear axle: https://www.ford-trucks.com/forums/1...l#post18992905
This 2020 F350 7.3 owner stated his truck is fitted with a Dana rear axle: https://www.ford-trucks.com/forums/1...l#post19024336
1c1. Standard F250 rear springs are three leaves regardless of wheel and tire size. Camper pkg adds an aux leaf, rear stabilizer bar, and stiffer front coil springs on trucks with 17” wheels and tires and 18” wheels and tires.
1c2. F350 SRW gets trickier. Assuming 18” or 20” wheels and tires, rear springs are four leaf plus an aux leaf. Camper package (n/a 20” wheels) adds rear stabilizer and stiffer front coils.
1d1. Max F250 7.3 GVWR is 10,000 lbs.
1d2. F350 7.4 4x4 GVWR up to 11,900 lbs available.
The F250 HDTT is only available with the diesel.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
HTH,
Jim / crewzer
HTH,
Jim / crewzer
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Regarding 1d2.: do you know what options guarantee the 11,900? In other words, are some combination of heavy service front, snow plow and/or camper package needed?
I consider this site to be a two-way street: I learn from it, and I try to contribute.
Thanks,
Jim / crewzer
2020 F350 SRW 7.3 4.30 4x4 CCLB with 18” wheels, LT275/70R18E A/T tires, and the snowplow/camper package.
For example: https://www.ford-trucks.com/forums/1...l#post19035086
Important update and clarification: https://www.ford-trucks.com/forums/1...l#post19085770
HTH,
Jim / crewzer
I truly appreciate the generous compliment. However, while I really like our truck, it’s really not a very good manual, IMHO, so I must disavow any association.
I was a product manager for many years, and I tried to get my team to deliver manuals based on the 5 Cs:
Clear
Correct
Concise
Consistent
Complete
IMHO, the OM doesn’t meet this standard.
Sincerely, however, thanks.
Jim / crewzer
Clear
Correct
Concise
Consistent
Complete
Jim / crewzer
I'm in the belief that when you order the 7.3 with 4.30s, you get the Dana axle. The 4.30s really increases your towing capacity and Ford feels the Dana is a better fit. The 2020 7.3 with 4.30s I saw locally backed that belief.
F250
F350
(BTW - I think Jim wrote the damn manual.)
F250
F350
and yes, Jim, I echo what was said. Thank you for your experience and knowledge here always!
Yes, I have seen two such equipped. Is there something else optionally that contributes to it, maybe????
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Not guaranteed, but the best we’ve been able to come up with so far is this:
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Thanks again, Gents!
Yeah, no camper package or snowplow/camper package for the F350 SRW Platinum due to the 20” wheels.
Member “Under-Pressure” has posted several times about his 11,900 GVWR ordering torture. For example:
https://www.ford-trucks.com/forums/1...l#post19065096
HTH,
Jim / crewzer
Thanks, I had previously followed that thread, but wondered if addition information had emerged. Building a 2020 f350 Platinum LB 7.3, 4.30: only 20" wheels are available and no camper package. I have not been able to find a window sticker with this configuration but I would assume the GVW would be limited to 11,500.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
HTH,
Jim / crewzer
On the dealer build site it showed up as 11900 gvrw with no camper package or snowplow package.
I ordered it with the lariat sport so that has the 20 inch wheels.
