1953-56 F100 302/5.0 swap: accessory configuration
Old Dec 23, 2019 | 02:59 PM
eff_it's Avatar
eff_it
Hi FTE,
From my measurements, it seems like some of the popular v-belt accessory bracket systems hang low and are about 25" wide which doesn't provide much clearance when the frame and inner wheel wells only have about 27" in width
Length measurements seem to indicate about 33" to play with. The shortest 5.0 configuration I have ever accomplised is 29-30" with the shorty water pump.
So has anyone run into width wise fitment issues with clockwise v-belt alternator and PS pump setups from CVF or March?
Do swappers generally use the "shorty" style water pump or are OEM style water pumps with "normal" hub heights typically good enough when using aluminum rad and electric fan?
Thanks in advance,
Mike
Old Dec 23, 2019 | 05:35 PM
EBEAR's Avatar
EBEAR
I am running the factory serpentine system off of a 92 f250 with a 351w and using a mechanical fan and the 92 rad . Your engine placement will have a big bearing on room and make sure you are placing the rad in the 6 cyl position .
Old Dec 24, 2019 | 02:37 PM
eff_it's Avatar
eff_it
Thanks Ebear!
I will be pulling the old motor and mocking up the new one (347 stroker) over the next few weeks. So I will hold off on buying a water pump and accessories until I settle on a location. I am using a TKO500 trans so that might change things up slightly.
Old Dec 24, 2019 | 03:21 PM
F100supercrew's Avatar
F100supercrew
Pulleys and brackets
I always use CVF v-belt set-up on my 302's with mechanical fuel pump with their alternator--water pump ( correct rotation for V-belt )- Sandersen 508 AC compressor--Saginaw PS pump-- 4 row Aluminum radiator with matching shroud- with Spall electric fan---Block coated Hugger headers-- Lots of room all away around
Old Dec 24, 2019 | 04:40 PM
EBEAR's Avatar
EBEAR
supercrew It also appears you have plenty of room for a mechanical fan if so desired .
Old Dec 24, 2019 | 06:21 PM
schoo's Avatar
schoo
is that a front sump oil pan? And what AC kit or is it a kit
Old Dec 26, 2019 | 09:36 AM
F100supercrew
Front pulleys
NO must use rear oil sump pan with Mustang II front suspension-- the parts I always use is from CVF racing-- great people and quality
The heads are 5/8" away from firewall and I use street rod Ford weld in motor mounts with rubber biscuits -- use electric fan and shroud combination VS mechanical fan then got to make fan shroud that does not give you a nice clean look
Old Dec 26, 2019 | 10:02 AM
ben73058's Avatar
ben73058
Hey Mike,
I'll put in a vote for using the shorty waterpump. It all depends on where
you decide to mount your engine/trans. Our set up is a 351W with an AOD. It all fit but it's tight
up front. We went with a MarkVIII electric fan set up as we were having trouble keeping it cool in Texas.
You need all the room you can get for a big 5 inch deep electric fan. I'd mock your's up & see what it looks like.
One vote for more room up front for you electric fan & belt set up.
Ben in Austin
1950 F1
Old Dec 26, 2019 | 09:14 PM
estout81's Avatar
estout81
eff it,
Don't know if this helps or not but, this is my 302 in a Ranger swap and should fit your truck with room to spare.
Old Dec 28, 2019 | 11:04 PM
eff_it's Avatar
eff_it
Thanks you guys, very helpful! I will let you know how it goes. Cheers!
Dman94
13
Feb 12, 2020 09:13 AM
Dman94
Dec 23, 2019 09:25 AM
Galendor
36
Sep 17, 2011 01:00 AM
hush210
Oct 16, 2006 05:04 PM
aj22ms
Aug 31, 2004 07:56 PM
