Colorado Chapter Join Chapter, Leader:
Q - how well do your Colorado trucks age ?
Old Nov 18, 2019 | 11:15 AM
Johns01's Avatar
Johns01
asking as I guy in toronto with a really rusty truck that needs replaced...
I;m looking for another white '01 supercab f150 and I've found a couple of them - one is out your way which brings me to that question , and knowing , some areas (?) get snow so I'd presume salt (?)
truck in question started out in VA and slowly relocated it's way across the US to now be in Colorado so it may still be ok
outer body appears mint with a dent but my rotted truck , already had terminal rust and still
looked mint from outside 4 years ago
I still have to set my self up with a broker/shipper for whatever truck I eventually go after but I might be looking for a volunteer to have a peek at this one for me
I kinda want the factory sunroof upgrade and white supercabs have proven hard to find with
one
here in toronto my options range from junk to trash to scrap..I've been truck shopping for 5 years with not much luck
pics - 4 years ago
- month ago
and the truck in Colorado
my white "street scene" smooth cowl top really helps correct the proportions of the truck without the "black hole" at the bottom of the windshield
bonus my a/c has not smelt like cow poo for 7-8 years it's been on there...so if you need a solution , THIS IS IT
Old Nov 21, 2019 | 05:19 PM
Colorado350's Avatar
Colorado350
It really depends on the truck, they don’t use salt but they use several chemical solutions that basically have the same effects. However, you don’t see the extreme rust out here that y’all see up north. Where is the truck located?
Old Nov 22, 2019 | 04:16 PM
Johns01's Avatar
Johns01
- says denver
thanks for checkin' in !!
https://www.autoblog.com/cars-for-sa...ord-F-150-2001
shadows on the driver's side of the box leave me wondering , maybe the box side is pushed in along with the dent at the wheel well top (?)
a mint southern box with no need of paint is 2K installed here
....one that needs a box side and paint ..eahhh..?- still better than fixing a rusty one
lol.. as much as I "hate" to share an add for something I might be interested in .. with those whom might have so much less trouble acquiring it ...
my truck has the same interior but I have the leather seats to toss at it in mine
it needs rockers and a rad cradle .. and a box .. and eventually everything that it doesn't need replaced now so replacement is a better way to go
- and , I am looking for a white sunroof supercab truck - same year match is a bonus as everything I have should also fit
ie- mine is the new parts truck
Old Nov 22, 2019 | 06:00 PM
Colorado350
So asking price is $3999. I’d contact them explain you’re interested BUT you’re in out of state. I would have them FaceTime you as they walk around the truck and you ask questions. If they have a lift as them put in the air and do the same thing. If they refuse RUN!
There’s DEFINITELY damage and rust on the bed, I would use that as a bargaining chip. And the truck is 2WD which is a huge drawback in a snow state.
They don’t need to know why you want the truck...DO NOT TELL THEM EITHER! If you drive it back you’re probably looking at $300-$500 for food, lodging, gas, plus potential days off of work and unforeseen issues etc. If you have it shipped probably $500-$700 but it absolutely problem free.
Old Nov 24, 2019 | 09:55 AM
Johns01's Avatar
Johns01
It would simply get shipped
I looking for a broker here that can take care of the final inspection , sale and shipping hassles
looking at carfax on the add it says it passed it's emissions test in august but I'm wondering how the safety / fit vehicle inspections deal works there?
here we have a safety inspection requirement to register a vehicle as title transfers
or you get a title stamped "unfit" which an inspection & pass later can remove and allow plating the vehicle
no yearly inspections and emissions stopped being checked here last april
I know some places the e test and safety inspection are one and the same
-if the truck has a pass for both I'd figure it shouldn't be in to bad of a condition , though I'd still need the Ontario inspection to get my plates on it
lol
it's not rusty until the body and frame go in different directions on bumps ..
Old Nov 24, 2019 | 11:50 AM
Colorado350
lol
Call the shop ask where they did emissions, then call that shop ask them about how they do everything. Then call your local emissions and ask them about what you’ve learned...lots of leg work but...
Old Nov 28, 2019 | 11:08 AM
ceetwarrior's Avatar
ceetwarrior
Most Colorado trucks are rust free. Unless they got brought here from another state early on then the rust shows up later in life. Much earlier than a Colorado truck. I wash my stuff underneath often and try to keep undercarriage painted with enamel. I feel bad for people that live else ware that have to deal with rust like that. It would drive me nuts.
Aaron-71
Paint & Bodywork
17
May 23, 2011 12:12 PM
Lumpy78
Sep 17, 2009 01:57 PM
maxedoutford
Mar 23, 2008 12:44 PM
SillySod
Alberta Chapter
May 16, 2007 02:01 PM
