Pcm pinout for my 89 f250 5.8, 4x4
Old Nov 4, 2019 | 03:10 PM
Meun207's Avatar
Meun207
I bought the truck as a semi project. The wiring harness on the engine and cab are different. I'm looking for the pinout for my cab pcm so I can figure out what goes where. Thanks in advance.
Old Nov 4, 2019 | 05:02 PM
subford's Avatar
subford
Is this what you want?
OR this one:
Old Nov 7, 2019 | 12:07 PM
Meun207's Avatar
Meun207
thanks! its exactly what im looking for
Old Nov 16, 2019 | 06:08 PM
Meun207's Avatar
Meun207
ok, so, I thought I had the wiring corrected. the oil and temp gauges are working. the check engine and engine lamp are working correctly. I still have a surge, I replaced thr iac motor, still surging. checked vacuum hoses. still surging. removed the spout connector, smoothed out, idles and runs better than it ever has. it would seem I still have a ignition wiring issue. I pulled the pcm and opened it up. saw no evidence of bad caps, no visible diode or resister , no burnt tracks. I was a tauto tech many years ago and I feel I should know whats going on, I don't. any ideas would be appreciated. thanks
Old Nov 17, 2019 | 06:45 AM
subford's Avatar
subford
Canister purge solenoid can cause it.
Also check the TPS and the MAP sensor.
stihl1488
Feb 3, 2024 07:22 PM
trailscout
Sep 25, 2018 10:57 AM
bigreddiesel89
Dec 23, 2017 04:01 PM
smactek
Jan 27, 2016 07:20 PM
JeepScrambler
Oct 18, 2014 01:37 PM
