Fuel fittings always tighten at wrong angle??
Old Nov 4, 2019 | 02:38 AM
Terry Veiga's Avatar
Terry Veiga
Trailering
Hello, I have tried way too many types of fuel fittings and combinations (brass, aluminum, chromed, adapters, elbows, etc.) and they all tighten down at random angles but never at the desired angle. How are you guys getting your fittings to be perpendicular?
Both these fittings on my fuel regulator tighten past the desired angle and doesn't align with the carb inlet nor the fuel hard line:
Old Nov 4, 2019 | 05:12 AM
Mr Metals's Avatar
Mr Metals
I've used 90 degree swivel hose barbs for similar applications. You'll need a male/male adapter and the swivel barb. Google them and see if it will help.
Old Nov 4, 2019 | 11:28 PM
Terry Veiga
Trailering
Mr Metals, thank you very much! Took me only a few minutes to find the perfect swivels:
3/8 Male NPT to 3/8 Barb 90-degree Elbow Fuel Fitting
3/8 Male NPT to 5/16 Barb 90-degree Elbow Fuel Fitting
Old Nov 7, 2019 | 12:19 PM
resonateur's Avatar
resonateur
...another is to use a fuel-resistant thread sealer and only tighten the fitting until it suits the position you want without over-tightening. They don't have to be muscled...
Old Nov 9, 2019 | 03:09 AM
Jigs_n_Fixtures's Avatar
Jigs_n_Fixtures
Yellow Teflon tape, and as Resonateur said, don’t over tighten them.
You can not back off a fitting. If you do it will leak.
JonathanN
70
Oct 21, 2019 09:25 PM
nathanr561
Aug 3, 2019 05:18 PM
A/Ox4
47
May 10, 2015 11:40 AM
JohnBOV43159
Apr 26, 2015 10:14 AM
marilyn
Oct 6, 2004 04:24 AM
