Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
New Member. I own a 1981 Ford C800
Old Oct 12, 2019 | 07:29 PM
Defbob's Avatar
Defbob
Hello everybody. I recently bought a Ford C800 with a 429 and Spicer 5052A tranny. It also has a 22K 2spd rear with code LB which is not in the manual. Just not sure what ratio it is. It is an ex power company utility truck. It has an Altec D990 rotating crane. It has 24,201mi and 622hrs on it. Everything works and the truck is clean. Wasn’t planning to keep the crane, but it is growing on me.
Old Oct 12, 2019 | 08:09 PM
Hillbillysuv's Avatar
Hillbillysuv
Pretty clean looking C series. Is that 429 exhaling though stacks?
I've got a 63 C850 myself. Numbers Dummy is the real brains behind this outfit but I've been tinkering with mine for about a year now so if you have any questions, hit me up I might have run across the answer.
Old Oct 13, 2019 | 01:13 AM
Defbob's Avatar
Defbob
The previous guy made the exhaust out of flex pipe from the manifolds up to the mufflers in the stacks. I’m going to make a better exhaust, but keeping the stacks. I posted a video on youtube under “releasing the 1981 Ford C800”. 1min video of it being back out of its resting spot, but it shows it running. Everything works, the guy I bought it from started it up, used the boom to move a 6V53 out of the way of the truck, stowed the boom, released the brakes, and backed it out to the front of his business. Not bad for $500...
Old Oct 13, 2019 | 10:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
Y = Class 8 - Air Brakes - 33,001-55,000 lbs. GVWR range.
C80 = C800 Tilt Cab (gas), Low Tilt.
K = 429 4V (7.0L).
0 = Check digit, FoMoCo use only.
B = 1981.
V = Kentucky Truck Assembly Plant.
J41935 = 1981 Numerical Sequence of Assembly, the trucks specific serial number.
6S = Chrome Yellow.
113129:
11 = Boston MA Ford District Sales Office, where the original selling dealer ordered the truck from.
3129 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
153" Wheelbase.
C804 = C800 Tilt Cab (gas), 34,000 lbs. Gross Vehicle Weight Rating.
BS8: BS = Black Heavy Duty Vinyl with Gray Appointments / 8 = Standard Cab.
SB = Spicer model CM-5052-A 5 Speed Direct.
LBP:
LB = Eaton model 22221 Two Speed Rear Axle / 7.17/9.77 / 22,000 lbs. Rear Axle Capacity.
P = Rockwell/Timken model FF-903 12,000 lbs. Capacity Front Axle with Power Steering.
Old Oct 13, 2019 | 10:41 AM
Defbob's Avatar
Defbob
Thank you. The Ford shop manual that came with the truck had all the info except for the rear axle this truck had.
Old Oct 13, 2019 | 11:07 AM
NumberDummy
See LB in pic from 1980/89 Ford 600/900 series Truck Parts Catalog, available on a C/D from hipoparts.com
Old Oct 13, 2019 | 11:59 AM
Defbob's Avatar
Defbob
this is the manual that came with mine and obviously does not have all of the info.
Old Oct 19, 2019 | 04:26 PM
Defbob's Avatar
Defbob
I changed the oil, replaced the battery, and temp. Fixed some electrical items in prep for the trip home. The guy I bought it from has been nice to allow me to keep the truck there to tinker on.
Old Oct 20, 2019 | 05:41 PM
Defbob's Avatar
Defbob
I got my truck home today.
Old Oct 20, 2019 | 06:42 PM
85e150's Avatar
85e150
I thought you were going to drive it home.....
Old Oct 20, 2019 | 07:45 PM
Hillbillysuv
Congratulations.
have you decided whether to keep the crane?
Old Oct 21, 2019 | 05:54 AM
Defbob's Avatar
Defbob
Originally Posted by Hillbillysuv
Congratulations.
Leaning towards getting rid of it
Old Oct 24, 2019 | 06:59 AM
Defbob's Avatar
Defbob
I pulled the carb last night to rebuild it. I’ll do a tubeup when I put the carb back on.
Old Oct 24, 2019 | 07:15 PM
Hillbillysuv
I need to check into the carb I got with the parts truck I bought from Destroked. I'm currently running the Edelbrock 1405 600cfm carb that was on my 534 when I bought it. It starts easily and runs pretty well but it really is too much carb. You'd think it would need a big carb, but it redlines around 3400 rpm while just about anything else in a passenger vehicle or even a motorhome will spin 4500 rpm with no issues.
If your carb is too far gone a 600 cfm or slightly smaller carb should work pretty well on that 429.
Old Oct 25, 2019 | 09:51 AM
telescope-tech's Avatar
telescope-tech
If you think you want to get rid of the crane, do it before you ever use it. If you use it a couple times you will wonder how you ever lived without one. At least, that was my experience. I bought a truck with a crane planning to just keep the cab and chassis but at this point I'd buy another truck for a cab and chassis and keep mine as-is because the crane has become the best part of the truck. YMMV or course!
