82 f150 with 351w performance cams?
Old Aug 9, 2019 | 10:36 PM
Hunter.879's Avatar
Hunter.879
I was wondering if anyone knows of a good performance cam for stock block and stock heads and for some smarts about performance cam because i dont know much about them.
Old Aug 10, 2019 | 03:04 AM
NZCOBRA's Avatar
NZCOBRA
Cam
Don't go too big ..., Comp 268 high energy , hydraulic flat tappet
Old Aug 10, 2019 | 07:57 AM
Franklin2's Avatar
Franklin2
Putting a aftermarket cam in a Ford can be a can of worms. The Fords do not have an adjustable valve train, so you cannot properly adjust the valve lash. There are several work-a-arounds so I would research and plan on having to use one of those if you need it. A couple of them are shims under the rockers, and longer or shorter pushrods.
