Air Intake 1981 F250
Old Aug 5, 2019 | 09:27 AM
BlueWhiteFord's Avatar
BlueWhiteFord
Hello,
I am currently working on restoring my truck fully and ran into some problems. It seems like there is a three-piece air intake originally. The air filter housing, some kind of flexible tube, and a plastic mouth that bolts into the front of the truck. That funnel/mouth bolts to a plate that is attached to the fender. My problem is that the plate is rusted through and I can not figure out in which way I have to weld it back together. If that as an original air intake could send me a picture that would be much appreciated. I have a 351M engine.
Old Aug 5, 2019 | 02:32 PM
1986F150six's Avatar
1986F150six
"The air filter housing, some kind of flexible tube, and a plastic mouth that bolts into the front of the truck. That funnel/mouth bolts to a plate that is attached to the fender."
Usually, the air cleaner snorkel has a flexible hose which connects to plastic "funnel" which is attached to the radiator support.
Old Aug 5, 2019 | 11:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BlueWhiteFord
Hello,
Old Aug 6, 2019 | 07:44 PM
Rusty_S's Avatar
Rusty_S
and good luck getting the 9600 part. Took me 2 years to finally track down a reasonably priced NOS unit.
Old Aug 21, 2019 | 10:59 PM
delco1946's Avatar
delco1946
Any luck? I can tell you that the image above is not accurate based on my truck which I believe to be all original and is a 1981 F250. I could poke around if you need a picture still
