Hard Braking - Whistle sound?
Old May 14, 2019 | 01:09 PM
robert_l_ross's Avatar
robert_l_ross
This is the 2nd time this has happened to me...someone cut me off and I got on the brakes -hard-, and a lower tone 'whistle' seemed to come from the dash area. Any idea what it could be? The truck stopped OK (maybe a little more brake force than I would have hoped to get it stopped, but it stopped with room to spare)...but I've only ever heard that sound once before, and it was under the same conditions.
Old May 14, 2019 | 08:18 PM
Cocky EX's Avatar
Cocky EX
Bertha does the same, but only if I get on pedal hard. Haven't given it much thought to be honest.
Old May 15, 2019 | 05:25 AM
01__Excursion's Avatar
01__Excursion
Fluid flow, valving sounds under heavy application in the Hydraboost maybe?
Old May 15, 2019 | 04:05 PM
TooManyToys.'s Avatar
TooManyToys.
Some vacuum boosters tend to do that with a rapid application.
Old May 20, 2019 | 09:05 AM
'88 E-350's Avatar
'88 E-350
Could be your brake booster diaphragm has a tear, or just normal air movement sound. If it only makes one quick sound as you're pressing the pedal downward, possibly normal. If it whistles while you're holding the pedal it's probably got a torn diaphragm. Try it with the engine running and the truck sitting still.
*2fords*
Jul 11, 2014 07:59 PM
whiskeyrichard
Oct 3, 2012 01:38 PM
jfletcher72
Jun 9, 2010 11:07 PM
2005X
Sep 25, 2009 06:40 PM
Jerrod
May 20, 2004 10:12 AM
