Holley 4160
Old Apr 11, 2019 | 01:35 PM
daveengelson's Avatar
daveengelson
Holley 4160
Duplicate thread, originally posted in the engine forum and do not know how to move post from a forum to another?The truck has set for the past couple of months while installing clutch and components. The carb ran fine prior and it is less than a year old. Started up this a.m. and fuel started spilling out, what I believe to be the vent for the primary metering plate? I adjusted the float level but I am not sure it was necessary since it would seem to me the problem is possibly in the metering plate? Sprayed carb cleaner down the vent but did not solve the problem. In adjusting the float level I loosened the screw and rotated the adjustment nut clockwise?
Appreciate suggestions on possible solutions greatly appreciated!
__________________
'problem with engaging in useless activity is never knowing when your done'
Dave
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.(Daily Driver)
65F100 CC, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
64 Lemans w/ GTO packageEdit Quote Multi Quote Quick ReplyReply Subscribed
Old Apr 11, 2019 | 04:47 PM
daveengelson
I thank you anyway, member, in the engine forum was able to help.
MainetoDC
Apr 26, 2017 06:46 PM
1987_XLT_Lariat_F250
Feb 22, 2016 03:12 PM
