need a little help, 14 6.2, coming home towing quad trailer going up hill it shifted down gave a little jerk then no throttle, will start but shuts right off, will try and get a computer on it asap, no check eng. light
thanks for any help only 40,000 miles on it
Not sure about the 6.2 trucks but that could be your fuel pump fuse. There is a TSB out for this (TSB 15-0137), and a relocation kit to move it. Seems to be a common problem that fuse overheating
Fuse 27 is in the under-hood box... Open the hood and you it will be right in front of you. Plenty of YouTube videos explaining how to replace it. Move it to location 70 as I recall. Dealer can do it, but they'll charge you... Fairly easy repair. Prevents a lot of headaches later on. Hope this helps.
Quick check and those sounds like fuel pump / fuel pressure codes. Was fuse 27 burnt up? If so, the relocation kit might be just the ticket to get you up and running.
checked what i could, fuse 27 no sign of short replaced it anyway no change, swapped 7 and 8 with others still no change, wife said thats it send it to shop will see what they come up with
well it is fixed , stupied bug got into mass air , had oil changed and they pulled air filter to check it must have disloudge the bug then went in to maf later, i know it had to be something stupid
