Sponsored by: Real Truck
Axle grinding noise when hot
Old Jun 17, 2018 | 09:42 PM
shot93's Avatar
shot93
Been a while since I posted anything on here. I have an F250 08, with 4.10 LS axles.when I have been driving for 50 or so miles I get a grinding noise and the truck shudders when I make a tight turn. It is more pronounced with a load and no matter what it does not do it when going straight or when I only drive a short distance. I have thought maybe the grease is breaking down when hot, or maybe the limited slip is going out. Any ideas would be appreciated.
TW
Old Jun 18, 2018 | 03:09 AM
seville009's Avatar
seville009
Definitely check the rear differential fluid first.
Old Jun 18, 2018 | 07:36 AM
shot93's Avatar
shot93
Yeah I am going to change the fluid this week. Hopefully that will help.
Old Jun 18, 2018 | 03:46 PM
svastano's Avatar
svastano
Do you have a carrier bearing on your driveshaft. That was my issue.
Old Jun 18, 2018 | 06:42 PM
mastersativa's Avatar
mastersativa
It sure sounds like your limited slip to me, not saying it's bad yet, but only doing it when turning is the key. My 03 expy does it quite loudly, and my 03 250 does it, not as loud, my 06 350 doesn't do it at all, only real difference is the fluid and modifier used in them. The 06 was just rebuilt and has synthetic with modifier in it, the other two 03's has synthetic without the modifier, it was added seperatly. I would recommend you change fluid, inspect what you drain out, and go from there.
Old Jun 18, 2018 | 08:10 PM
shot93's Avatar
shot93
Thanks I think that is what I am going to do. Change fluid and modifier.
d5332
1997 - 2003 F150
13
Aug 10, 2011 09:22 AM
CobraGT40
Aug 30, 2010 10:40 PM
rugermack
Dec 11, 2007 07:47 AM
cableguy17866
Apr 18, 2007 09:23 PM
winchcable
1997 - 2003 F150
Apr 16, 2003 07:02 PM
