Sponsored by: Real Truck
2008 f350 v-10 p0191 code
Old Jun 17, 2018 | 09:03 AM
Snocam's Avatar
Snocam
Hi everyone. I don't post much but read the forum often. A week ago much truck died on the road while towing our camper, threw the p0191 code . I nursed it home, it would start ok than want to die again after a few miles. So far I have replace the fuel pump, filter , pressure sensor on the fuel rail, and the fuel pump control module at the rear of the truck . It still isn't running right, and driving me crazy . Any ideas on what the issue is would be greatly appreciated . Again, truck is a 2008 f350 v-10 long bed crew cab 4x4.
thanks,
snocam
Old Jun 17, 2018 | 09:14 AM
DogRidesInBack's Avatar
DogRidesInBack
Off the top of my head, fuel pressure regulator (IDK if it is a separate part or built into the pump on your vehicle), worn wiring, corroded connectors, vacuum leaks.
Old Jun 17, 2018 | 09:44 AM
Snocam's Avatar
Snocam
Yeah I actually checked all the grounds and connectors. I believe the fuel pressure regulator is the module I replaced last night. I guess vacuum leaks are a possibility. I also treated the fuel in the tank in case I might have a bad batch from the last fillup..
thanks for the reply
snocam
Old Jun 18, 2018 | 04:19 PM
Snocam's Avatar
Snocam
Finally broke down and took the truck to a mechanic. He put a gauge on the fuel line in front of the filter, only getting 30 psi and drops off from there, should be 50 to 60. Looks to be electrical in nature.
Old Jul 1, 2024 | 11:04 PM
magnumak1's Avatar
magnumak1
if solved what was the solution?
Syoungs
Modular V10 (6.8l)
Aug 13, 2023 07:34 AM
Bill Payne
Jul 5, 2018 09:10 AM
kingarther2002
Modular V10 (6.8l)
Oct 20, 2015 09:44 AM
pete315
Apr 14, 2010 05:41 PM
jfboy
May 7, 2009 12:04 PM
