Tennessee Chapter Join Chapter Leader: harleymsn
1994 F150 5.0
Old Nov 13, 2017 | 06:05 PM
Bigmonts's Avatar
Bigmonts
1994 F150 5.0
What are some of the things that can run a battery down? It usually takes 4/5 days without being cranked. Have changed the key cylinder, alternator, and battery. Thanks!
Old Mar 28, 2019 | 01:01 PM
Blackbeauty95's Avatar
Blackbeauty95
Trailering
SAME HERE 🤨👎
Old Apr 9, 2024 | 10:52 AM
78eatingmymoney's Avatar
78eatingmymoney
Trailering
Try taking a volt meter and check different plugs. You may find a wire that is hot after key is off. Think of things that would run if key is on like lights, radio, fuel pump. Can check light sockets with bulb out to see if anything is still hot. It being a newer truck will have alot of checks. Hope this helps.
Old Apr 9, 2024 | 10:55 AM
78eatingmymoney
Trailering
Quick fix is get a bettery disconnect switch you can turn off and install it somewhere convienient like inside cab under seat or under dash.
Draconwolff
2009 - 2014 F150
Aug 27, 2017 08:44 AM
burnout01134
Mar 18, 2016 01:33 PM
tonyperiat78
17
Aug 29, 2006 07:26 AM
66f100
Jan 24, 2005 05:01 PM
tdsimmo
Feb 22, 2003 07:24 PM
