Sponsored by: Real Truck
1999 350 steering issue
Old Oct 18, 2017 | 09:17 AM
rssnape's Avatar
rssnape
I have a 1999 350 SD 7.3 SRW Long Bed, 245K. I have been chasing down steering slop at dead center for some time now.
To date I have done the following:
  1. Red Head steering gear
  2. New spring bushings front and rear
  3. New Sway bar bushings front
  4. New track bar
  5. New tie rod ends
  6. New drag link end
  7. 1 new ball joint
I still have a loose spot in the center. I am thinking that it may be in my column as that is basically the only spot that has not been addressed.
Are there any replaceable parts in the column, or should I look at a complete column? Any advice on source for those parts?
Thanks
Scott
Old Oct 18, 2017 | 10:33 AM
redford's Avatar
redford
FTE Leadership Emeritus
There is always going to be a little loose or vague feeling. It is just the nature of a straight front axle 4x4 truck with a steering gear box.
Take 5 PSI out of your front tires and see how that feels to you.
Old Oct 18, 2017 | 11:33 AM
rssnape's Avatar
rssnape
It was not that way when I bought the truck with 100k on it. Definitely not "normal" but manageable. I would like to get it to "good".
Old Oct 18, 2017 | 11:47 AM
Colorado350's Avatar
Colorado350
Did you adjust the new Redhead gearbox?
DanielT28
Sep 2, 2014 09:48 AM
LARIAT 85
Jul 31, 2008 02:57 PM
gusthebus
Mar 7, 2005 06:16 PM
jazzy66
Apr 11, 2004 11:23 PM
JQ
Oct 19, 2002 06:04 PM
