'05 Middle row seats won't unlock - help
Old Oct 17, 2017 | 04:21 PM
rdbrownlaw's Avatar
rdbrownlaw
Trailering
I folded my middle row down the other day to haul some stuff. Now, no matter what I do, I can't get them to unlock and fold back up. Any ideas at all?
Thanks,
Russ
Old Oct 17, 2017 | 04:43 PM
Twonky's Avatar
Twonky
Thanks,
Russ
Check the L bracket that links the release handle to the cable. Mine was bent and not pulling properly. I’ll add some photos later to show what I’m talking about
Old Oct 17, 2017 | 06:55 PM
rdbrownlaw's Avatar
rdbrownlaw
Trailering
Thanks - I look forward to the picture. I'll go look at that.
Old Oct 18, 2017 | 07:16 AM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
x2
Lift up the seat bottom and follow the push/pull cable to the latch, see what's holding it. A friend's Excursion had this problem when he bought it...a little adjustment of the bracket and all worked well again.
Old Oct 18, 2017 | 08:47 AM
Twonky's Avatar
Twonky
I got my seat features confused. The L brackets I referred to was for the slide feature.
Check both latch catches on right and left side to seat while pulling release handle, larger rectangle shaped on on seat base.
Left side
Right side
They are connected with this cable, trace it and lubricate all parts, straighten anything that seems out of alignment. Tighten cable if necessary.
steel cable kinda like on bicycle brakes
There are also springs used to return handles to original position, check to see that those are intact and operational.
Also try pushing seat back down, maybe the switch didn't engage in the full down position. Try pulling up for same reason. Don't forget to pull up on larger rectangle leaver on seat base.
I hope this is helpful
Old Oct 18, 2017 | 09:01 AM
Twonky's Avatar
Twonky
One more thing to try
If your front seat is too far back it might be pushing against the seat that is flipped forward and the top of the folded down back seat, mine does that too. Move the front seats forward and push on the flipped forward seat to release pressure off of the seat back. Seems to work for me.
Old Oct 18, 2017 | 01:30 PM
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
+1 on moving front seats up to release pressure on back seat springs.
50calmike
Aug 29, 2008 06:09 PM
chaz3
Jun 25, 2007 10:45 AM
spikedog
May 8, 2006 06:49 PM
tazmanian_cowboy
Sep 1, 2005 08:28 PM
dlafleur
Dec 21, 2004 08:17 PM
