Carb tuning thread ( start with secondary spring)
Old Sep 5, 2017 | 02:39 PM
beartracks's Avatar
beartracks
I'm running a Street Demon 750 (new) with vacuum secondaries. It comes with the plain steel colored pod spring. I'm trying to decide if the spring opening rates in the link below are based on wide open throttle or if the throttle position doesn't matter.
http://documents.holley.com/lit350rev.pdf
i.e. at low/medium rpm cruise is it going to be open somewhat or wait till I mash on the gas.
Old Sep 8, 2017 | 12:18 PM
lee's Avatar
lee
Hi,
I picked up a spring assortment package. It contained around 8 different colored springs.
The secondaries operate based on engine load. In Park/Neutral you can floor the gas and the secondaries will not open as there is no load on the engine. I only bring this up cause some folks don't realize this.
I put a paper clip on the rod coming out of the vacuum canister, up against the canister. Then took the truck for a drive. When the secondary opens it will slide the clip down the rod. After you test drive, pop the hood to see where the clip is.
Play with different springs till you get the opening to occur that provides opportune performance.
If you put to light a spring in,... the secondaries will open to soon and cause a bog.
Take care,
Old Sep 8, 2017 | 12:27 PM
beartracks's Avatar
beartracks
Good idea, At one time I had a micro switch that wold show me when they stated to open.
I understand the secondaries wont open in nuetral, what I'm not sure of is if their opening rate (as per the chart) is totally dependent on RPM (internal vacuum source) or if the load plays any part. It would seem they need both rpm and load (low manifold vaccum) to open. Of course the are limited by the main throttle opening.
Old Sep 8, 2017 | 12:43 PM
lee's Avatar
lee
I think you are on track.... RPM and Load... load plays the primary part.
Arizona84F150
13
May 5, 2017 01:45 PM
Khauler
Jul 26, 2011 05:47 AM
crazyeddie
Aug 5, 2010 09:35 PM
fordeverpower
15
Apr 4, 2006 02:12 PM
jds1971
Sep 11, 2002 06:29 PM
