I have a 1963 F100 4x4 292 with 11 x 1.75” rear brakes. I am looking for a breakdown diagram with part numbers for the brakes. I am completely rebuilding the brakes and have located all components (I think) except for the spring that goes on the spreader bar.
My old springs are both broken.
No luck at any local auto parts stores.
Closest I have found (in link below) is PN 2A601…but not sure if it is correct. https://www.ford-trucks.com/forums/1...ar-brakes.html
The 2A601 is what is called the base part number - that spring across all models uses the same base part number - then you have to dig into the text within that base number to find the correct full part number for the specific application
C4UZ-2A601-A - Parking Brake Link Spring - 2 each
About 18 available NOS at these vendors. Click on this link to get names and phone numbers. I'm not going to retype all of that like ND does.
