12V wattage in 03 Expedition and 110v install
Old Jul 17, 2017 | 05:06 PM
rmathiasen's Avatar
rmathiasen
4wd Low
I am curious how much wattage I can pull from the 12v cigarette lighter ports in my 2003 Expedition EB to possibly be used for charging a computer and/or running a ham radio?
I am also curious if I would be able to install a 110v, wall style outlet in the vehicle for the same purpose and how much wattage would I be able to draw from it?
I believe this is the fuse that is for the cigarette lighters in the truck if that helps. It is 20a, and handles the OBD2 port and the cigarette lighters if I'm not mistaken.
Thanks for any help you can provide me!
Old Jul 18, 2017 | 08:45 AM
lincolnshibuya's Avatar
lincolnshibuya
P(power)=I(current)*V(voltage)
max is 240 watts.
https://www.facebook.com/diyLincolnNavigator/
Old Jul 18, 2017 | 10:42 AM
Brett_N's Avatar
Brett_N
I wouldn't try and draw 20A from the cigarette lighter though. The math is correct, but doesn't take into effect the wiring that is in there. I'd limit to around 10A max or you may find a smoldering pile of metal that used to be an expedition. especially on an older truck that the wiring may be starting to get brittle on.
Oops I deleted my own edit
For the HAM, you probably need an
inverter like this guy inverter like this guy
For the PC - you can use that same inverter,
or get one like this. or get one like this.
just make sure you get the correct one for your laptop model.
If you want to drive a higher wattage inverter, hard wire some good 8 guage wire with a good quick-connector right to the battery and feed it through the firewall. that way you can keep the inverter and battery in the locked truck.
Old Jul 18, 2017 | 11:01 AM
rmathiasen's Avatar
rmathiasen
4wd Low
Thanks for the help from you both. I think I will just go with the Amazon inverter for now because it will work fine for my needs.
Old Jul 18, 2017 | 04:33 PM
rmathiasen's Avatar
rmathiasen
4wd Low
Follow up: Would I be able to install USB ports for charging my phones?
Old Jul 18, 2017 | 04:58 PM
lincolnshibuya
of course you can, the fuse will blow up first if you're over the maximum load. As long as the fuses are the correct ratings don't be scared of causing fires or overheating. The fuses are designed to prevent that kind of accidents unless somebody put the wrong kind of fuse (putting 30A on a 20A circuit)
Old Jul 18, 2017 | 09:43 PM
Skauber's Avatar
Skauber
Personally, if I were to install something which draws a high amperage, I would make a dedicated circuit for this unit directly from the battery through a proper fuse and a relay controlled by the ignition. I would not rely on stock wiring to supply a permanently mounted inverter which is more than 100W in power.
antonov225
All Things Towing
Jun 19, 2018 07:05 AM
magseven
May 26, 2008 10:32 PM
rpowell911
Electrical Systems/Wiring
Aug 15, 2006 02:46 PM
ryanshirley
Jul 9, 2005 05:07 PM
WMostellar
Oct 29, 2002 09:10 PM
